Author Topic: SD card upgrades brick Windows Phone 7 handsets  (Read 1775 times)
« on: November 15, 2010, 21:24 »
Microsoft Phone 7 users have been warned not to upgrade handset memory or use the phone’s SD card in other devices, after it emerged that the handsets alter the memory card’s format.
According to Microsoft, removing the original SD cards can cause data loss and stop the handset from working properly, limiting upgrade options that might have been a key purchasing motivation for media hoarders.
“You should not remove the SD card in your phone or add a new one because your Windows Phone 7 device might not work properly,” Microsoft said on its support site.
Read more: http://www.pcpro.co.uk/news/362788/sd-card-upgrades-brick-windows-phone-7-handsets
Re: SD card upgrades brick Windows Phone 7 handsets
« Reply #1 on: November 16, 2010, 00:15 »
fecking microshaft.
« Reply #2 on: November 16, 2010, 09:42 »
Ironically, if they'd made it non-removable, like the iPhone, there wouldn't have been an issue.  Why make it removable if it f***s the phone when you take it out, and it can't be used anywhere else anyway?
:dunno:
« Reply #3 on: November 16, 2010, 10:34 »
:dunno:
it's because they're microsoft  :-X
« Reply #4 on: November 16, 2010, 10:42 »
« Reply #5 on: November 16, 2010, 11:22 »
I can see some Araldite appearing on production lines soon.
« Reply #6 on: November 16, 2010, 12:43 »
