Author Topic: inkjet printer advice  (Read 12256 times)
Re: inkjet printer advice
« Reply #15 on: January 07, 2011, 15:55 »
Colour or mono, Clive. How many PPI?
Offline D-Dan
« Reply #16 on: January 07, 2011, 17:24 »
The advantages of inkjet for photos are:
i. Better colour matching
ii. You can print to glossy paper.
Hence having one of each (inkjet and laser) is the better option. Unfortunately, since my aborted (and to be renewed) attempt to emigrate, I lost both and so I', stuck my with my brother's crappy HP MFP now :(
I miss my good printers and scanners  :bawl:
Steve
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
« Reply #17 on: January 07, 2011, 17:31 »
I only need one that does the job, so I still have the Brother DCP-330C that I bought a couple of years ago.
« Reply #18 on: January 07, 2011, 17:56 »
M
Mono Rik.  The other specs are:
Model Name ML-2010 (SP20MPU)
Print Speed Up to 20 ppm in A4 (22 ppm in Letter)
Resolution 1200 x 600 dpi
First Printing Time 10 seconds (from Ready)
Warmup Time 30 seconds
Power Rating AC 110 - 127 V (USA, Canada) /
220 - 240 V (Others), 50 / 60 Hz
Power Consumption 320 W average during operation /
Less than 6 W in sleep mode
Acoustic Noise b
b. Sound Pressure Level, ISO 7779.
Stand by: Less than 35 dB;
Printing: Less than 53 dB
Sleep mode: Background noise
Toner Supply Single cartridge
Toner Cartridge Life c
c. The number of pages may be affected by operating environment, printing interval, media type, and
media size.
3,000 pages at ISO 19752 5% coverage
(Ships with 1,000 pages Starter Toner Cartridge)
Duty Cycle Monthly: Up to 5,000 pages
Weight 5.8 Kg (including Toner Cartridge)
Package Weight Paper: 1.2 kg
Plastic: 0.2 kg
External Dimensions (W x D x H) 358 x 299 x 217 mm / 14.1 x 11.8 x 8.5 in.
Operating Environment Temperature:10 ~ 32 °C / 50 ~ 90 °F; Humidity: 20 ~ 80
% RH
Emulation SPL (Samsung Printer Language)
Random Access Memory (RAM) 8 MB (non expandable)
Fonts Windows font
Interface USB 1.1 (Compatible with USB 2.0)
OS Compatibility d
d. Please visit www.samsungprinter.com to download the latest software version.
Windows 98/
« Reply #19 on: January 07, 2011, 18:30 »
Use a 120 screen if you have the option, Clive. That will give you 101 shades of grey.
« Reply #20 on: January 07, 2011, 18:31 »
Oh, how useful!  :)x
« Reply #21 on: January 07, 2011, 18:32 »
1% increments, it's as good as you need. :)
« Reply #22 on: January 07, 2011, 20:09 »
Just ignore him Rik.  Oh nothing new there then!   :)x
