Author Topic: 40Mbps FTTC Broadband  (Read 10735 times)
« on: December 15, 2010, 20:12 »
My exchange is rolling out 40Mbps FTTC Broadband at the end of next March and it would cost £25 a month with my present provider (ID Net).  What benefits would I have by signing up given that I'm not a downloader nor a gamer?   :dunno:
Re: 40Mbps FTTC Broadband
« Reply #1 on: December 15, 2010, 23:32 »
One for Rik, me thinks.  ;D
« Reply #2 on: December 16, 2010, 00:04 »
what do you have now?
I doubt it offers much for you. Unless you watch online tv?
« Reply #3 on: December 16, 2010, 00:45 »
I wondered if it might offer a more stable connection - but it has it's share of troubles for some users.
« Reply #4 on: December 16, 2010, 04:34 »
doubt it. noise, noise noise.
« Reply #5 on: December 16, 2010, 09:31 »
Depends what you want to do, Clive. I've decided not to bother as I don't watch TV via the 'net and don't do a lot of downloading - 6GB is normally enough most months. In your case, you would gain speed and stability, it's a case of whether that is worth it for you.
« Reply #6 on: December 16, 2010, 10:14 »
I have the standard up to 8 Meg at present Sam.  That usually means 4 or 5 meg which is very satisfying.  But I do have this strange noisy line problem from time to time which nukes my connection  until I can get someone at BT to sort it out.  I just wondered if the fibre system might solve the problem once and for all.
« Reply #7 on: December 16, 2010, 10:16 »
It should, as you'll only have a few hundred metres of copper at most. I have, though, to emphasise should.
« Reply #8 on: December 16, 2010, 10:19 »
So it will be fibre from where to where?
« Reply #9 on: December 16, 2010, 10:35 »
It would certainly speed up those artistic streaming movies i've heard can be viewed on the interweb  :thumbs:
« Reply #10 on: December 16, 2010, 10:43 »
 :devil:
« Reply #11 on: December 16, 2010, 10:52 »
Rik will correct me, but I believe it's fibre from the exchange to the box (cabinet) from which your individual line eminates, Clive.
« Reply #12 on: December 16, 2010, 11:16 »
No need for correction. :thumbs:
« Reply #13 on: December 16, 2010, 13:09 »
my traffic to and from the office eclipses 6BG a month, nevermind other things
« Reply #14 on: December 16, 2010, 18:30 »
I communicate briefly, though some would argue otherwise. ;)
