Author Topic: 40Mbps FTTC Broadband  (Read 10737 times)
Re: 40Mbps FTTC Broadband
« Reply #15 on: December 16, 2010, 18:36 »
Rik will correct me, but I believe it's fibre from the exchange to the box (cabinet) from which your individual line eminates, Clive.
The box is quite close so that would certainly eliminate a lot of the potential problems.
« Reply #16 on: December 16, 2010, 18:57 »
Not if the problems are between the box and your house.
« Reply #17 on: December 16, 2010, 19:39 »
Exactly.
« Reply #18 on: December 17, 2010, 18:22 »
The noise is back with a vengeance and I've had further problems with t'internet dropping down and out today.  I phoned IDNet and told the guy about the "battery touching" (James I think) and he said it means two lines are in contact with each other which could be dangerous as electricity is being conducted down the line.  On several occasions it has sounded as if someone else was on the line, albeit very faintly so that makes a lot of sense.  He's despatching a BT engineer but if it's the same guy as usual then I'm doomed.   :bawl:
« Reply #19 on: December 17, 2010, 18:26 »
At least you didn't have to phone Mumbai, Clive. This is such a standard fault that I'm amazed BT haven't yet sorted it.
« Reply #20 on: December 17, 2010, 18:33 »
HaHa!  You don't know the guy who calls on me!   ::)
« Reply #21 on: December 17, 2010, 18:38 »
He's one of their better ones, at least he recognised there was a fault!
« Reply #22 on: December 17, 2010, 21:13 »
Lots of tea and biscuits should help him do the job properly, Clive.  Or, perhaps, a banana.  ::)
« Reply #23 on: December 18, 2010, 10:51 »
Bacon sandwich, it never fails...
« Reply #24 on: December 18, 2010, 11:01 »
Unless he's a Muslim.  ;)
« Reply #25 on: December 18, 2010, 11:13 »
There is that risk. :)
« Reply #26 on: December 18, 2010, 11:41 »
HaHa.  Just had an error message when I tried to use Google.  "Connection speed too slow to use Google Search".   ::)  My phone is crackle -free this morning so I'm sure it will resync eventually.
« Reply #27 on: December 18, 2010, 12:15 »
Optimist. ;D
« Reply #28 on: December 18, 2010, 16:42 »
Maybe tomorrow.   :D
« Reply #29 on: December 22, 2010, 08:54 »
At long last!  It's resuncked to 4Meg.   :laugh:
