Author Topic: Boot Disc Failure, another one....  (Read 33940 times)
Re: Boot Disc Failure, another one....
« Reply #15 on: January 06, 2011, 12:58 »
Installing Linux ALWAYS works :)
Steve
indeed.
« Reply #16 on: January 06, 2011, 12:58 »
I bet Sam's plan has installing Linux mentioned somewhere. ;D
it would have, yes
« Reply #17 on: January 06, 2011, 13:02 »
« Reply #18 on: January 06, 2011, 13:35 »
I might as well install a new OS, as everytime I restart my computer, it has to use the CD .
And when I turn it off, as I have just done, it installs of the updates that it downloaded, again.
If I had a gun, I'd shoot it!   >:(
« Reply #19 on: January 06, 2011, 14:38 »
Can't you re-install XP, Kate?
Offline D-Dan
« Reply #20 on: January 06, 2011, 15:31 »
What exactly IS the boot problem? It may be an easy fix :)
Steve
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
« Reply #21 on: January 06, 2011, 15:57 »
indeed it might be, especially if its an mbr issue.
« Reply #22 on: January 06, 2011, 16:04 »
Is that short for member, or Kate in this instance, Sam? ;D
« Last Edit: January 06, 2011, 17:54 by Rik »
« Reply #23 on: January 06, 2011, 17:51 »
Just to show how clever I am - Master Boot Record.  :smart:
« Reply #24 on: January 06, 2011, 17:54 »
Why would Kate need a record of her master's boots? :D
« Reply #25 on: January 06, 2011, 18:16 »
:sigh:
« Reply #26 on: January 06, 2011, 18:22 »
Offline D-Dan
« Reply #27 on: January 06, 2011, 19:38 »
If she knows where his boots are, she knows where the master is  :o:
Steve
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
« Reply #28 on: January 06, 2011, 20:17 »
Dangerous talk around here, Steve.  :devil:
« Reply #29 on: January 06, 2011, 23:51 »
simply -argh.
