Author Topic: Boot Disc Failure, another one....  (Read 32390 times)
Re: Boot Disc Failure, another one....
« Reply #60 on: January 07, 2011, 16:06 »
A lot of ice cream?  :o:
« Reply #61 on: January 07, 2011, 17:25 »
For new users, Mint is about the best. http://www.linuxmint.com/
Downloading the DVD now.  At last, a legal use for torrents!  ;)
« Reply #62 on: January 07, 2011, 18:27 »
It's the one I went for. v10?
« Reply #63 on: January 07, 2011, 18:31 »
Yup.
« Reply #64 on: January 07, 2011, 18:33 »
I had a quick look at the live CD then Xmas overtook me.
« Reply #65 on: January 07, 2011, 18:35 »
It overtook you?  How far back did it leave you behind?   :)
« Reply #66 on: January 07, 2011, 19:15 »
About 10 days. ;D
Offline D-Dan
« Reply #67 on: January 07, 2011, 19:39 »
You should have no problems with Mint - pretty much everything just works (including media).
You'll be pleased to know it comes with Transmission bit torrent client, so you can get back to illegal downloading pretty quickly ;)
Steve
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
« Reply #68 on: January 07, 2011, 19:45 »
« Reply #69 on: January 07, 2011, 20:01 »
Oh, I'm not going near it, Steve.  It's just for emergency uses, unless I get bored with hacking forums.   Oops, shouldn't have said that...   :blush: :scoot:
Offline D-Dan
« Reply #70 on: January 07, 2011, 20:16 »
In that case, you may want to make a note on the disk of the AV - ClamAV, which is not a part of the standard distribution (you can "install" in a live environment should you need it - it just won't be there after a reboot). Other tools such as gparted (partition editor) are included as standard, and data recovery where Windows simply won't boot doesn't need any special software, just the built in file manager.
Steve
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
« Reply #71 on: January 07, 2011, 20:48 »
Ouch!   :stars:
« Reply #72 on: April 02, 2011, 12:34 »
Update on the dead HDD, it is dead!  :bawl:
But a friend of Michael's managed to get the data transferred to an external HDD.
So I bought a new HDD and it has been formatted and I think XP has been installed. I think, means that this is what I requested, but not necessarily what was installed.  ::)
Now the new problem is that when trying to install the drivers for the GFX card it blue screens and goes in to memory dump????
I have been informed that I can use it, but..... the graphics may look a bit strange....  ':|
Apparently this problem is beyond the boy geniuses who have tried to fix it.
« Reply #73 on: April 02, 2011, 12:38 »
Hi Kate
Is there an error code being displayed when it blue screens?
« Reply #74 on: April 02, 2011, 12:48 »
Hi Rik, how have you been?
I have no idea about the error message. I did ask ask, but was informed that it was just the blue screen then the memory dump.
I do seem to remember that it was doing similar before the HDD died.
Attention to detail isn't there strong point.  ::)
Just thought there might be something obvious, as I haven't looked at it myself.
