Author Topic: Nexus S Runs Ubuntu; Linux Replaces...Linux  (Read 1336 times)
« on: January 12, 2011, 02:25 »
It seems like hackers who inatall the Android operationing system on everything decided to mix it up a bit. The folks over at XDA Developers have successfully ported Ubuntu HD2 version 0.3 to the Samsung Nexus S phone. You read that correctly: They replaced a Linux-based OS (Android) with a Linux-based OS (Ubuntu).
http://www.pcworld.com/article/216440/nexus_s_runs_ubuntu_linux_replaceslinux.html
Re: Nexus S Runs Ubuntu; Linux Replaces...Linux
« Reply #1 on: January 12, 2011, 11:51 »
 :stars:
« Reply #2 on: January 12, 2011, 12:32 »
« Reply #3 on: January 12, 2011, 12:37 »
They've been putting Android on iPhones too.  Can't see the point.  If you want an Android phone, buy one.  If you want an iPhone, buy that!
« Reply #4 on: January 12, 2011, 14:24 »
yeah but then there is the "can I do it?" attitude. Also android is better than the iphone os, however the iphones are cutting edge in screen tech. If I had the time I'd probably mess around with it - though I don't even own a smart phone.
« Reply #5 on: January 12, 2011, 17:33 »
The Andriod OS may be 'better' then iOS (it's certainly more configurable), but I think the 'pot luck' app store lets it down somewhat.
« Reply #6 on: January 12, 2011, 20:26 »
not sure it quite so pot-luck but I get what you mean
« Reply #7 on: January 12, 2011, 21:10 »
Yeah, I just feel there should be some soft of approval system for the apps, but I expect it will come.
« Reply #8 on: January 12, 2011, 21:14 »
Well they are checked, I thought, for malicious code.  Apart from that, why check?
« Reply #9 on: January 12, 2011, 21:22 »
Weren't there a couple of apps removed because of malicious code?  Removed from phones, that is.  I'm not knocking Android, it's alright, but at the moment, I just prefer the iPhone.
« Reply #10 on: January 12, 2011, 21:28 »
indeed there were if I remember correctly.
