Author Topic: A Look at Linux Mint Debian Edition  (Read 2223 times)
« on: January 19, 2011, 04:16 »
I have a fairly wary relationship with Debian GNU/Linux, so I had to wonder how things would go with the new Linux Mint Debian Edition.
http://www.linux.com/learn/tutorials/398287-a-look-at-linux-mint-debian-edition
Re: A Look at Linux Mint Debian Edition
« Reply #1 on: January 19, 2011, 11:31 »
Getting itchy fingers again, Sam? :D
« Reply #2 on: January 19, 2011, 12:12 »
Knowing my propensity for having to try all options of most things, I still think the trouble with *nix is that there's simply too much choice.  :stars:
« Reply #3 on: January 19, 2011, 12:15 »
I know how you feel, Simon, and every variant seems to have its denigrators and evangelists.
Offline D-Dan
« Reply #4 on: January 19, 2011, 14:06 »
I've been using LMDE for the past 3 - 4 weeks (I replaced Linux standard edition with it), and I have to say I like it. Sure, it's more hands on than buntu based distros, and you have to occasionally compile stuff from source. Some times things don't work (I found a dependancy problem with one of the developer libs in the repository, for example, meaning that any compilation requiring that lib will fail). However, it's stable, based on a good foundation, won't be lead by Marc Shuttleworth's vision (and therefore, will not include the unity desktop), and if you include level 5 updates it should never need re-installing again, since then it becomes a full rolling release.
ATM some of the repositories are a little out of date, but once Debian Squeeze hits final release that should change.
Steve
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
« Reply #5 on: January 19, 2011, 15:10 »
interesting, I might have to give it a go then.
But Simon/Rik - probably not one for you two.
« Reply #6 on: January 19, 2011, 16:10 »
« Reply #7 on: January 19, 2011, 16:15 »
That's a relief, Sam. ;)
