Author Topic: Notebook battery  (Read 3304 times)
Offline jww41005
Notebook battery
« on: January 21, 2011, 13:07 »
Hello Pals,
I'm looking for a new battery.
It is a 10.8V and the majority of the batteries that I find on the net are 11.1V
In your opinion would this difference make much of a difference to my notebook.
Cheers
John
If it works, don't fix it
Re: Notebook battery
« Reply #1 on: January 21, 2011, 14:25 »
I guess it might not provide enough power.
What is the spec of the battery? i.e. make, what notebook for?
Offline jww41005
« Reply #2 on: January 21, 2011, 15:57 »
Hi Sam,
First of all it's for an Acer Aspire One ZG5. I use it generally for surfing and Word, nothing too heavy. It's usually on for an hour or two five days per week.
Li-ion Battery pack
Model UM08A52
10.8V
2.7 Ah
2900mAh
32Wh
There are plenty on the net, but 11.1V
What do you think?
John
« Reply #3 on: January 21, 2011, 15:59 »
You should be OK, John, provided they fit. I take it you're out of warranty?
Offline jww41005
« Reply #4 on: January 21, 2011, 16:10 »
Hi Rik
Yep. No warranty.
My daughter got it from a friend, and she gave it to me. It's called notebook laundering :D
If I get one more thumbs up I'll get one.
Thanks Rik
« Reply #5 on: January 21, 2011, 16:15 »
I just store the spares under the desk, John. :)
« Reply #6 on: January 21, 2011, 16:16 »
I bought one similar to yours off ebay , but it was the long life one that lasts 6 hrs for £32.00 6 months back
http://shop.ebay.co.uk/i.html?_nkw=+UM08A52&_sacat=0&_odkw=l+UM08A52&_osacat=0&_trksid=p3286.c0.m270.l1313
« Last Edit: January 21, 2011, 16:18 by TR »
Offline jww41005
« Reply #7 on: January 21, 2011, 16:20 »
TR
How's it doin'. OK?
« Reply #8 on: January 21, 2011, 17:14 »
Doing ok  :thumbs:  it's a bit more bulky than a normal battery but ok.
« Reply #9 on: January 21, 2011, 19:12 »
Hope this pic helps, just this moment taken it.
Offline jww41005
« Reply #10 on: January 22, 2011, 20:49 »
Perfecto
Thanks for that TR. And it's the same colour as mine.
I bought a battery this afternoon off ebay.
Cheers :thumbs:
« Reply #11 on: January 22, 2011, 21:46 »
hope it all works out
Offline jww41005
« Reply #12 on: January 31, 2011, 21:22 »
The battery arrived today, and it fits!
It charged up well. No problems.
As you can see, it came well packed.
« Reply #13 on: January 31, 2011, 21:26 »
nice! glad it all worked.
Online Simon
« Reply #14 on: January 31, 2011, 21:52 »
Thanks for letting us know, John.  :thumb:
