Author Topic: Session Verification  (Read 12965 times)
Offline Delgado
« on: February 04, 2011, 09:11 »
When I go to click on "Mark all Topics as read" I get this-
Session verification failed. Please try logging out and back in again, and then try again.
Whats this all about?
Re: Session Verification
« Reply #1 on: February 04, 2011, 10:20 »
One for Sam, I think. I see it occasionally, but only in certain circumstances, and these wouldn't apply to you. Do you use the cookie to keep you permanently logged in, which browser and OS are you using?
« Reply #2 on: February 04, 2011, 10:25 »
Try logging out, clear the cookie, then log back in again, DG.
« Reply #3 on: February 04, 2011, 10:29 »
Or that. ;D
« Reply #4 on: February 04, 2011, 13:27 »
Yep, if that doesn't work we will have to take a better look at it.
Offline Delgado
« Reply #5 on: February 04, 2011, 18:51 »
Just signed out, cleared cookie, and signed in again. Seems to have worked this time ok. Im using Firefox Browser and Windows 7 System. Will keep you informed if its ok after a few days.
« Reply #6 on: February 04, 2011, 18:58 »
:x:
« Reply #7 on: February 04, 2011, 18:58 »
Thanks DG.  It could be just 'one of those things'.  Usually, things like that are a knackered cookie.
Offline Delgado
« Reply #8 on: February 06, 2011, 09:53 »
No good!! Happening again! Had this twice since last post.
Im using Firefox with Windows 7 and AVG Antivirus.
« Reply #9 on: February 06, 2011, 10:35 »
When you start up Firefox, does it restore your previous browsing session, DG?
Offline Delgado
« Reply #10 on: February 06, 2011, 12:41 »
No it brings up my Home Page
« Reply #11 on: February 06, 2011, 12:43 »
It might be worth starting with a blank page, just to eliminate that as a cause.
« Reply #12 on: February 06, 2011, 12:45 »
We've had no other reports, DG, hence, initially, suspecting a browser issue.
Offline Delgado
« Reply #13 on: February 06, 2011, 17:30 »
Think Ive found the answer. Ive recently got a new PC and installed the favourits from an image file, and Ive been using the old link!
Now altered to the new link, seems ok now-will continue to monitor.
 :crazy:
« Reply #14 on: February 06, 2011, 17:34 »
 :thumbs:
You might want to look at the FEBE add on, which makes it very easy to migrate a Firefox setup.
