Author Topic: 'C' drive running out of space  (Read 3886 times)
« on: February 06, 2011, 12:51 »
A friend has an XP machine, and keeps getting warning messages that C drive is running out of space.  This is a partition on a larger drive, but only 20Gb has been allocated for Windows and programs, so I suspect it's getting clogged up with temp files, and the recycle bin.  Is there any way to allocate more space to a C drive, without formatting the whole drive?
Re: 'C' drive running out of space
« Reply #2 on: February 06, 2011, 12:57 »
Thanks.  I suspect that will be a job for me.   :bawl:
« Reply #3 on: February 06, 2011, 13:05 »
Aren't they always?
« Reply #4 on: February 06, 2011, 14:24 »
Seem to be.  Trouble is, it takes me twice as long as it should, because I only vaguely know what I'm doing - but I still get asked!
:sigh:
Offline D-Dan
« Reply #5 on: February 06, 2011, 15:00 »
You can do it relatively quickly and easily using gparted running from a linux live cd.
Steve
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
« Reply #6 on: February 06, 2011, 15:14 »
That's if you know how, Steve.  ;)
« Reply #7 on: February 06, 2011, 15:24 »
I use Easus on windows
You can enlarge or change particians many other processes with a hard drive
Just go slow and
DO NOT REFORMAT or all will be lost
http://bit.ly/5s5wos
« Last Edit: February 06, 2011, 15:26 by davy51 »
« Reply #8 on: February 06, 2011, 16:00 »
Thanks Dave, I'll look at that one too.  :)
« Reply #9 on: February 06, 2011, 16:06 »
It's shareware...
« Reply #10 on: February 06, 2011, 16:40 »
One time use Rik
Im sure I could find a free legal license if its needed more
Home edition is free
http://www.partition-tool.com/personal.htm
« Last Edit: February 06, 2011, 16:43 by davy51 »
« Reply #11 on: February 06, 2011, 16:42 »
 :thumbs:
« Reply #12 on: February 06, 2011, 17:35 »
I'd have suggested that.. 8-)
« Reply #13 on: February 06, 2011, 17:43 »
Thought you might.  ;D
« Reply #14 on: February 06, 2011, 17:43 »
Of course you would, Sam. ;D
