July 08, 2024, 15:33
Technical Help & Discussion
General Tech Discussion, News & Q&A
Harddrive
Topic: Harddrive (Read 1075 times)
dessy
New Member
Harddrive
February 07, 2011, 15:59 »
Hi there, Im new on hear and would like to ask a question
Ive got a sharp pc-gp10-cm notebook and need to buy a harddrive, could any one tell me what type of hard drive will fit the sharp notebook ! I tryed using my hard drive out of my toshiba laptop but it would not fit.
Thanks for your time Dessy..
Re: Harddrive
February 07, 2011, 16:19 »
Hi Dessy and welcome to the forum. If you've tried a drive already, presumably you have removed the old one. What size was it, did it have a manufacturer's label on it?
Re: Harddrive
February 07, 2011, 16:26 »
Dessy!
dessy
New Member
Re: Harddrive
February 07, 2011, 16:53 »
Hi, I got it from a auction, There was no harddrive in it. i found that out when i got home. Thanks Dessy.
Re: Harddrive
February 07, 2011, 17:17 »
As far as I can find a spec, you need a 2.5", 4200rpm or better SATA drive, but there doesn't seem to be a lot of information out there.
dessy
New Member
Re: Harddrive
February 07, 2011, 18:38 »
Hi , Thanks a lot thats grate ! im going to go and check out some prices.
Im very surprised how quick you get help on hear Thanks a lot. Kind regards Dessy..
Re: Harddrive
February 07, 2011, 18:44 »
No problems, come back if you need more help.
Harddrive
