Author Topic: Problems with cabled BT hub  (Read 1746 times)
Offline Saddler125
  • New Registration
« on: March 23, 2011, 07:56 »
Hi Folks,
My wifes wireless adaptor on her desktop started playing up recently so I connected to the BT hub using an ethernet cable. Now my laptop will not connect to the wireless network - unless I reset the router everytime I switch on - very strange  :stars:
The wierd thing is my netbook still works on the wireless as before with no problems ????
Any suggestions folks - it's a long way to that reset button  :cry:
Re: Problems with cabled BT hub
« Reply #1 on: March 23, 2011, 10:29 »
Hi, and  :welcome:
Have you tried setting up a new network connection on the laptop?  Will it not connect at all, or is it connecting to the network, but not the Internet?
« Reply #2 on: March 23, 2011, 16:40 »
Hit the repair button on the lappy connection, see if that can find anything wrong. Welcome to Pals. :)
Offline Saddler125
  • New Registration
« Reply #3 on: March 25, 2011, 15:25 »
Thanks Folks, I decided to go for broke and deleted the old connection - then set up a new network connection after a few attempts it now seems to work fine - even with the desktop plugged in on cable.
Cheers. :-* :thumbs:
« Reply #4 on: March 25, 2011, 16:10 »
We like happy endings. :)
« Reply #5 on: March 25, 2011, 20:20 »
Indeed, thanks for letting us know.  :)
