Author Topic: Connecting Ubuntu To Internet  (Read 5075 times)
« on: March 26, 2011, 16:47 »
How can I connect Ubuntu 10.10 to the internet using a wireless dongle on my laptop?  When I go to Network Connections - Wireless a box opens asking for the SSID, BSSID, Device MAC address and Cloned MAC address.  What values should I enter and how do I find them?
Re: Connecting Ubuntu To Internet
« Reply #1 on: March 26, 2011, 17:52 »
Sam!!!!  ;D
« Reply #2 on: March 26, 2011, 22:31 »
I've been having my own computing issues today.... and I just upgraded to Ubuntu 10.10.
Ok - network connections...  for me I just get a list of all the networks I can see. Firstly I'd try and click on the network icon on the desktop (right hand side by the clock) - this should list all networks detected. If not then you should just need your wifi routers SSID....
« Reply #3 on: March 26, 2011, 22:34 »
Perhaps you should try Windows, Sam.  :devil:
« Reply #4 on: March 26, 2011, 22:42 »
oh no - I had a hd error. had to fsck this disk and then i decided it was time to distribution upgrade.
I have vista and will be using it shortly to play FM2011... :-)
« Reply #5 on: March 26, 2011, 23:30 »
Luckily, I've never had a fscked disc, but that reminds me, I must run a backup.  :)
« Reply #6 on: March 27, 2011, 00:17 »
Done that - I get a message that wireless is disabled.
I've tried that but the dialogue box also asks for all the further information listed in my original post.
« Reply #7 on: March 27, 2011, 07:27 »
The wireless is disabled? I don't suppose the computer has a WLAN has a switch somewhere on the computer?
As for ask for the rest of the info - hmm, so it doesn't let you continue without all the boxes filled in? For me (and I'm running Ubuntu 10.10) - it allows me to hit ok only with SSID filled in - which is just your wireless connection name.
« Reply #8 on: March 27, 2011, 10:08 »
Should it not detect the other settings automatically, once a connection has been established?  :dunno:
« Reply #9 on: March 27, 2011, 10:56 »
No, there's no WLAN switch on the computer.  The only switch turns the power on or off.
Could it be that Ubuntu 10.10 doesn't recognise my wireless dongle?  It's a Belkin, but I don't have much more info than that*.  I've just run a system test which detected the following controllers:
Broadcom Corporation BCM4311 802.11b/g WLAN (rev 01)
Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
*Edit:  It's a Belkin F6D4050 v1 which has a MAC code and SN number.
« Last Edit: March 27, 2011, 10:59 by GillE »
Offline D-Dan
« Reply #10 on: March 27, 2011, 12:05 »
http://ubuntuforums.org/showthread.php?t=1509403
Read through the whole thread. The OP there got it working.
Steve
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
« Reply #11 on: March 27, 2011, 14:36 »
That's a very useful link, Steve - thanks :) .
I've followed the advice in that thread and my dongle is now recognised :) .  However, the icon at the top right of the screen insists that the wireless network is disabled.  Any more thoughts?
« Reply #12 on: March 27, 2011, 15:50 »
Can you open a terminal, type:
iwconfig
- this should give you some output about the device.
As with no swtich there is no key commadn like FN+some F function that could disable the card?
Offline D-Dan
« Reply #13 on: March 27, 2011, 15:53 »
Try right clicking the network icon in the tray (I assume it's there in Ubuntu - debian user myself) which should pop up a menu. Make sure that wireless is enabled there.
Steve
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
« Reply #14 on: March 27, 2011, 19:02 »
Sam, you were right - there's a function key on the keyboard which was locking the wireless signal.
After many years of enduring a slow Windows XP OS, my husband bought a new laptop yesterday and gave me his old one to see if I could run Ubuntu on it.  So far I like what I see :) .
