Author Topic: Video Format For Sansa Fuze  (Read 2964 times)
« on: April 11, 2011, 16:56 »
I have a Sansa Fuze mp3 player connected to my Ubuntu machine and I would like to convert some videos to play on it.  Unfortunately, the Sansa video conversion software is only compatible with Windows.
I could, of course, convert them on a Windows machine then transfer them across to the Ubuntu machine.  However, I feel as if this would be a cop-out.  Is it possible to do the conversion using Ubuntu?
Re: Video Format For Sansa Fuze
« Reply #1 on: April 11, 2011, 22:18 »
Haven't a clue, Gill, but we know a man who does...   ;)
« Reply #2 on: April 11, 2011, 23:42 »
I don't see why not.
What happens when it is connected? Does it work just like an external hard drive?
« Reply #3 on: April 12, 2011, 00:29 »
Yes, it works just like an external hard drive.
« Reply #4 on: April 12, 2011, 01:20 »
So can you just copy the files?
If so they should just play with the right codec - well determining what the right one is - I think it uses mp4 files.
Incidentally I came across: http://stevebarcomb.us/WordpressBlog/sansa-fuze-works-great-with-ubuntu-and-rythmbox/
and they link to: http://code.google.com/p/video4fuze/downloads/list
I'd try this first, if this doesn't work we can always use ffmpeg to convert things
« Reply #5 on: April 12, 2011, 12:44 »
Success!
Thanks for the links, Sam.
« Reply #6 on: April 12, 2011, 21:20 »
See, I was right!  :smart:
« Reply #7 on: April 12, 2011, 22:57 »
You were indeed right, Simon.
The next question will be how to remove the Windows partition from the computer altogether!  It's performing so much better under Ubuntu that I begrudge Windows the space it's occupying on the HDD.  Perhaps I'd better start another thread...
« Reply #8 on: April 12, 2011, 22:59 »
I think you'd be right to, Gill.  :)
« Reply #9 on: April 12, 2011, 23:39 »
maybe.. .worth keeping on for the time being though, I still have a windows partition for a few games that run better under it that ubuntu. You never know when you might need it - and well its not hassle having both.. unless you are desperate for disk space?
