July 05, 2024, 12:44
Technical Help & Discussion
General Tech Discussion, News & Q&A
Microsoft found a way to forever eliminate the Blue Screen of Death.
Topic: Microsoft found a way to forever eliminate the Blue Screen of Death. (Read 2543 times)
April 25, 2011, 07:42 »
It will now be the Black Screen of Death.
LINK
GillE
Never totally serious
Re: Microsoft found a way to forever eliminate the Blue Screen of Death.
April 25, 2011, 09:29 »
It's a pity they're not focussing their attention on preventing any Screen of Death appearing instead of tinkering with colours. Who are Microsoft employing nowadays - software engineers or graphics designers?
(Schopenhauer,
Die Kunst Recht zu Behalten
April 25, 2011, 11:52 »
I thought BSODs had been virtually eliminated with Windows 7.
April 25, 2011, 13:18 »
Hell no, it's a regular occurrence on Mrs Clive's laptop. Usually at startup but a reboot usually fixes it.
April 25, 2011, 13:30 »
seems strange. I mean, yes, linux/macs crash, but if they do they either properly hang (once in a year from my experience) or they give you a nice useful error message.
April 25, 2011, 13:46 »
Yes, 'nice useful error messages' don't come into Microsoft's vocabulary.
April 25, 2011, 15:37 »
Hers does a full memory dump.
April 25, 2011, 16:55 »
That's the problem then, Clive, screw the cover down and it can't fall out.
April 25, 2011, 21:17 »
I'll have to drill a few holes in it.
Reply #9 on:
April 26, 2011, 00:49 »
run memtest!
Reply #10 on:
April 26, 2011, 08:48 »
It does that automatically.
Reply #11 on:
April 26, 2011, 13:31 »
no.
Reply #12 on:
April 26, 2011, 14:42 »
If memtest is the same as "Checking physical memory" then that's what it does. Then it's happy again... at least for a while.
Reply #13 on:
April 26, 2011, 14:45 »
well not to worry then...
but its not the same thing - but probably does a similar thing. Memtest probably gives more detailed results.
Reply #14 on:
April 26, 2011, 16:02 »
Memtest is third party software, isn't it? Wouldn't have thought it to be bundled in with Windows.
