Author Topic: Installing Ubuntu 11.04  (Read 2956 times)
« on: May 01, 2011, 20:55 »
Ubuntu 11.04, also known as the Natty Narwhal, arrived on April 28th, 2011 and is the 14th release of the Ubuntu operating system.
http://news.softpedia.com/news/Installing-Ubuntu-11-04-196660.shtml
Re: Installing Ubuntu 11.04
« Reply #1 on: May 02, 2011, 08:56 »
 :banana: :evilban: :banana: :evilban: :banana: :evilban: :banana: ;)
« Reply #2 on: May 02, 2011, 11:02 »
It still doesn't play television using my Hauppage DVB-T tuner card!
Offline D-Dan
« Reply #3 on: May 02, 2011, 11:53 »
Try with hts-tvheadend (http://www.lonelycoder.com/hts/tvheadend_download.html).
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
« Reply #4 on: May 02, 2011, 14:13 »
Thanks, Dan.  I've downloaded it and I'm pretty sure I've installed it correctly but I can't find it!
 :blush:
« Reply #5 on: May 02, 2011, 15:30 »
Type    Tvheadend
in a terminal it should pop up
Or to reconfigure  sudo dpkg-reconfigure hts-tvheadend
Then right click choose properties and it should tell where its at
other than that right click  choose  edit menus
and search there
« Last Edit: May 02, 2011, 15:32 by davy51 »
« Reply #6 on: May 03, 2011, 13:56 »
Well, I'm having more joy than I've ever had with MythTV, but that's not saying much  :laugh: !  I can get it to detect a handful of channels, mostly porn, children's and ITV2+1, but they won't play.  It would be nice to access the likes of BBC 1, ITV et al.  Although I've looked at the forum, I can't see any solutions there - quite a few people have experienced similar problems to me but no answers have been forthcoming.
Any more ideas?
« Reply #7 on: May 03, 2011, 15:06 »
Seems I remember someone having the same problem awhile back that I read on a forum
Try this search in google
http://is.gd/lPkWQJ
If not ask on linux mint forums  someone there should know
« Last Edit: May 03, 2011, 15:08 by davy51 »
Offline D-Dan
« Reply #8 on: May 03, 2011, 16:01 »
 :blush:
Sorry for the hold up - open your browser and go to http://127.0.0.1:9981
It's a web based interface - but works wonderfully and has an integrated vlc based player.
Edit: OK - a quick run through to get you going. First things first - click configuration and then "access control" and make sure that you enable a user with full access. - otherwise you are stuffed.(see image - no password should be needed)
Then click TV adapters and select yours from the drop down list. Add DVB by location and select your nearest transmitter. Wait until nothing is scanning (status panel top right) then Map services and leave it to it - this is the actual tuning. When it says "idle" in the bottom console it's finished. Then you can go back to Electronic Programme Guide tab and start watching. If channels are missing let me know, and I'll talk you through manual mapping.
Steve
« Last Edit: May 03, 2011, 16:10 by D-Dan »
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
