November 27, 2024, 21:52
Technical Help & Discussion
Old PC. Fix or recycle?
Topic: Old PC. Fix or recycle? (Read 2675 times)
jww41005
Regular Member
May 02, 2011, 20:55 »
Hello Pals,
I’ve got the ‘old’ family PC in front of me that decided to stop working a while back. I’m trying to decide if it’s worth some time and effort – 10 mins maybe - or shall I just recycle it.
The known problem with it is that absolutely nothing happens when the start button is pressed.
When I turn the power off on the back I hear the transformer whining down slightly.
No lights. Fan doesn’t spin.
I put the HDD in a docking station and it appears in My Computer on my laptop. It is divided into storage space and the OS. Vista. I've transfered some docs to it without any problem.
I was thinking about checking the HDD for errors or reinstalling windows, which I’m not sure how to do when it’s on a docking station.
What’s your first opinion?
Cheers
John
If it works, don't fix it
Re: Old PC. Fix or recycle?
May 02, 2011, 21:18 »
First, and possibly only thing I might try, is another power unit.
D-Dan
Regular Member
May 03, 2011, 02:09 »
Or if you can get a replacement MB without spending big money,
maybe
try that, too.
Phenom II X4 965, overclocked
Radeon HD4670 (1Gb)
8Gb RAM
1.25 Tb HD
Arch Linux (Custom build with custom kernel)
May 03, 2011, 09:58 »
I'd certainly start at the PSU.
jww41005
Regular Member
May 03, 2011, 17:35 »
Hi guys,
I got a responce from the PSU.
I shortened pin 14 and 15, green and black cable (Don't try this at home kids, or adults) and the fan in the PSU started to spin. I assume that the output will be ok.
What do you reckon?
May 03, 2011, 17:38 »
Only one way to find out.
jww41005
Regular Member
May 14, 2011, 15:15 »
I've decided to let it rest in peace, basically because there's a shop down the road that sells reconditioned PCs for the price of a resonable MB.
John
May 14, 2011, 17:29 »
They all end up in the computer graveyard eventually John.
Just make sure you trash your Hard Drive to make certain nobody steals your information.
May 14, 2011, 17:35 »
A large hammer is recommended...
Reply #9 on:
May 14, 2011, 17:48 »
that and a drill, making holes and placing the bits elsewhere works quite well.
Reply #10 on:
May 14, 2011, 17:54 »
Failing which, a blowtorch can do a reasonable job.
jww41005
Regular Member
Reply #11 on:
May 14, 2011, 21:43 »
You're all a bunch of psychos
Reply #12 on:
May 14, 2011, 22:45 »
Reply #13 on:
May 15, 2011, 10:44 »
Quote from: jww41005 on May 14, 2011, 21:43
Have you only just worked that out?
