Author Topic: iPod  (Read 40539 times)
Re: iPod
« Reply #15 on: June 08, 2011, 21:31 »
as you can guess, I used to live on my ipod. All difference now with my phone does everything in one. Still I love being able to listen to music on the go.
I was gonna say don't get a nano  - I have one but the touch screen is a little small and fiddly for me... but works like a dream.
Downloading music, I hate itunes - I much prefer play.com - as I find it cheaper and easier. But iTunes is click and go.
Re: iPod
« Reply #16 on: June 08, 2011, 21:31 »
Oh and the audio quality is nicely improved by using proper headphones and not the s**t that apple give by default.
Re: iPod
« Reply #17 on: June 09, 2011, 10:25 »
Been there, Rod.
Re: iPod
« Reply #18 on: June 09, 2011, 14:50 »
So how much would itunes charge for 60's downloads?
Re: iPod
« Reply #19 on: June 09, 2011, 14:58 »
I wouldn't know  :o: .
Re: iPod
« Reply #20 on: June 09, 2011, 15:06 »
Re: iPod
« Reply #21 on: June 09, 2011, 17:22 »
same price as all music, though I recall the Beatles albums are more expensive on itunes than CD. I prefer CDs and rip them and stick them on the device.
Re: iPod
« Reply #22 on: June 09, 2011, 18:03 »
Which means no DRM too. :)
Re: iPod
« Reply #23 on: June 09, 2011, 18:51 »
Can you please cut to the chase and give me a ball park figure?   ::) ;D
Re: iPod
« Reply #24 on: June 09, 2011, 19:33 »
 :dunno: 99p
Re: iPod
« Reply #25 on: June 09, 2011, 19:58 »
WHAT???   That's twice as much as I paid back in the 60's when they were brand new!!!  >:(
Re: iPod
« Reply #26 on: June 09, 2011, 21:12 »
and that's per track.
Re: iPod
« Reply #27 on: June 10, 2011, 14:47 »
So, I've found the iPod in a seemingly unopened box.  It's a 30GB 7500 songs variety if that is meaningful.  The box contains the iPod, a USB cable and a pair of naff earphones but no CD.  Is there supposed to be one?   :dunno:  It says I must attach it to my computer which I did several hours ago and it displays the message "Do not disconnect".  What happens next?   :D
Re: iPod
« Reply #28 on: June 10, 2011, 16:15 »
Clive, you need to download itunes 1st
http://www.apple.com/uk/itunes/download/
Forgot to say RTFM  ;D
Re: iPod
« Reply #29 on: June 10, 2011, 16:33 »
I'm surprised there isn't a disk in that type. I'm guessing its the one that isn't touch screen? Windows media player should have connected to it but I guess first use probably does mean using itunes
