Author Topic: iPod  (Read 39497 times)
Re: iPod
« Reply #30 on: June 10, 2011, 17:22 »
There's no manual to read Terry.   :laugh:  OK, I'm downloading iTunes.  Gulp.  I don't think it has a touch screen Sam.  But there is an inlet for the steam and pressure gauge if that's any help?   :dunno:
Re: iPod
« Reply #31 on: June 10, 2011, 17:47 »
Re: iPod
« Reply #32 on: June 10, 2011, 17:48 »
I've downloaded iTunes and reformatted and updated the device since it was Mac only.  It's now Windows and I have the desktop thingy dashboard whateverucallit.  So where is all this 60's stuff?   :bawl:
Re: iPod
« Reply #33 on: June 10, 2011, 17:50 »
Stop press!  It's fully charged!
Re: iPod
« Reply #34 on: June 10, 2011, 18:08 »
Yipee! Aldi had a solar charger for iPods and phones yesterday, Clive, might be worth checking if it's still around.
Re: iPod
« Reply #35 on: June 10, 2011, 18:20 »
Now you need to go back to your PMs, Clive.  ;)
Re: iPod
« Reply #36 on: June 10, 2011, 18:25 »
Offline Baz
Re: iPod
« Reply #37 on: June 11, 2011, 13:29 »
I have a Nano and tried and didnt like itunes so had a bit googling and found there is other software available to manage your music stc.
I found this site that tells you how to install itunes with out the bloat,then you can use which ever software you like.I use mediamonkey  its good enough for what I need and its a decent player too.I cant put photos on my nano from mediamonkey but I didnt want it for that, just music so thats ok
Re: iPod
« Reply #38 on: June 11, 2011, 14:28 »
Thanks Baz.  This is all a big adventure for me at the moment and I'm still looking for Greensleeves played by King John's minstrels.
Re: iPod
« Reply #39 on: June 11, 2011, 14:53 »
I could do you a version by the York Waites, Clive. ;D
Re: iPod
« Reply #40 on: June 11, 2011, 16:37 »
The original is always best Rik.   ;D
Re: iPod
« Reply #41 on: June 11, 2011, 16:47 »
Re: iPod
« Reply #42 on: June 11, 2011, 22:13 »
Any update? Did you get onto an itunes account ?
Solar charger eh rik might have to have a look
Re: iPod
« Reply #43 on: June 11, 2011, 22:43 »
I haven't made a great deal of progress today but I've received further instructions from a forum member.  Tomorrow may be a big day.   ;D
Re: iPod
« Reply #44 on: June 11, 2011, 23:03 »
I had green sleeves before I discovered Kleenex.
