Author Topic: iPod  (Read 40535 times)
Re: iPod
« Reply #60 on: June 13, 2011, 11:39 »
I already have a USB charger but there will be times when I won't have access to a computer so a mains charger will be good.
?? I'm talking about a mains charge which provides a 5V rail via a USB socket, Clive.
http://www.amazon.co.uk/Genuine-Apple-A1299-MB706B-Adapter/dp/B002FDGJNM/ref=sr_1_18?ie=UTF8&qid=1307961462&sr=8-18
£4.84 for the Apple one.
Most speakers sound pretty poor, they're worth spending a bit of money on. If you have a John Lewis or similar nearby, get them to demonstrate.
Re: iPod
« Reply #61 on: June 13, 2011, 11:42 »
Well I was hoping to get small "cube type" speakers as headphone aren't always convenient.  I lied about the Fifty Cents, but I do want to delete a song which was mistitled in the listings.   :laugh:
Re: iPod
« Reply #62 on: June 13, 2011, 11:48 »
If you want to treat yourself a little, I'd highly recommend this iPod speaker dock, which would also act as a charger:
http://www.amazon.co.uk/gp/aw/d/B00422U0E8/ref=mp_s_a_1?qid=1307961874&sr=8-1
Unfortunately, it was a lot cheaper when I bought it, but you can get similar for less.  The sound is very warm, rather than tinny, which you can get from some smaller speakers.
Re: iPod
« Reply #63 on: June 13, 2011, 11:48 »
Not sure that that power adaptor would be suitable Rik as it still relies on the availability of USB which I won't have if I'm away on holiday.  My £2 speakers from Maplin are not at all bad.  I'm not saying they are good either.   ;D
Re: iPod
« Reply #64 on: June 13, 2011, 11:50 »
Shiat!  I'm not paying that!!  I'm an OAP you know!  I'd have to go without food for a month!   :bawl:
Re: iPod
« Reply #65 on: June 13, 2011, 11:53 »
No, it relies on the availability of a mains socket, Clive.
Re: iPod
« Reply #66 on: June 13, 2011, 11:56 »
OK, how about something like this:
http://www.amazon.co.uk/gp/aw/d/B000K2YZNQ/ref=mp_s_a_9?qid=1307962436&sr=8-9
Check the reviews, though.
Re: iPod
« Reply #67 on: June 13, 2011, 12:05 »
I've ordered the power adaptor.   :thumbs:
Re: iPod
« Reply #68 on: June 13, 2011, 12:31 »
Re: iPod
« Reply #69 on: June 13, 2011, 12:46 »
You'll give him a stroke with that, Rik!  ;D
The one I linked to will also act as a charger, so these really are an all in one solution.
Re: iPod
« Reply #70 on: June 13, 2011, 12:58 »
It does sound good, though. :)
Re: iPod
« Reply #71 on: June 13, 2011, 20:27 »
Bose  :nerd:
Re: iPod
« Reply #72 on: June 13, 2011, 20:35 »
Looks very interesting but I will have to go without heating for a week.   :dunno:
Re: iPod
« Reply #73 on: June 13, 2011, 21:25 »
So many questions.  I'm really getting the hang of this now and I've downloaded loads of songs.  Well two actually.  More if you count the ones I deleted.  How would I go about changing the order of the songs on my playlist?  Some seem to download much faster than others.   :dunno:
Re: iPod
« Reply #74 on: June 13, 2011, 21:44 »
you should be able to drag and drop the songs into the order of the playlist... you can also do it on the device...
