Author Topic: Forum Upgrade  (Read 24215 times)
Re: Forum Upgrade
« Reply #15 on: June 30, 2011, 12:45 »
I've a sneaking feeling that it's possibly to do with the way the 'Unread Posts' page is now being cached.  I may be wrong, why should today be any different?
Re: Forum Upgrade
« Reply #16 on: June 30, 2011, 12:47 »
I think its all done in the database, so should be browser independent. But I'll take a look.
Offline Baz
Re: Forum Upgrade
« Reply #17 on: June 30, 2011, 14:39 »
like every change on any site it takes time to adjust to it.
so far all I can say i'm not keen on is the new/no new posts icons.they are a bit 'samey' bar the colour which may be awkward to distinguish to some people
and maybe the header bars are a bit too dark on the blue
Re: Forum Upgrade
« Reply #18 on: June 30, 2011, 14:43 »
you mean the header bit that say PC PALS and has the messages and time?
Offline Baz
Re: Forum Upgrade
« Reply #19 on: June 30, 2011, 14:45 »
yeah those and each individual topic header
Re: Forum Upgrade
« Reply #20 on: June 30, 2011, 14:54 »
I personally like the stark contrast. I'm sure me other half wouldn't agree though... but we'll take a look at it. All suggestions are welcome, even if we do just ignore them  :P
Re: Forum Upgrade
« Reply #21 on: June 30, 2011, 15:13 »
Unfortunately, we can't adjust the theme to every individual taste.  If we make the menu bars lighter, some people won't like that either.  It does also take a while to get used to changes.
The new posts icons can be changed, though.  What would you suggest, Rod?  They would obviously have to fit in with the colour scheme, so banana yellow would be out of the question!  ;D
Re: Forum Upgrade
« Reply #22 on: June 30, 2011, 15:20 »
...so banana yellow would be out of the question!
Philistine.   >:(
Re: Forum Upgrade
« Reply #23 on: June 30, 2011, 15:24 »
Re: Forum Upgrade
« Reply #24 on: June 30, 2011, 15:39 »
What I'll do is make the 'new' icon more of a green colour, like on the old board, yes?
Re: Forum Upgrade
« Reply #25 on: June 30, 2011, 15:43 »
I like that idea. Though the banana....
Offline Baz
Re: Forum Upgrade
« Reply #26 on: June 30, 2011, 18:06 »
or like a closed-envelope-never-been-seen-yet type icon, compared to something that has been seen  :dunno:
some thing along those lines.  old/new etc.
I dont know.not very imaginative me  ;D
or just  have the words  'new posts'   'no new posts'   :D :D :D
Re: Forum Upgrade
« Reply #27 on: June 30, 2011, 18:57 »
Phew!  For a moment, I thought something was wrong with my monitor.
Nice work!   :)
Re: Forum Upgrade
« Reply #28 on: June 30, 2011, 19:03 »
Thanks Dave!  :)
Re: Forum Upgrade
« Reply #29 on: June 30, 2011, 19:06 »
Baz, I'll look at those later.  :)
