Author Topic: Forum Upgrade  (Read 22534 times)
Offline Baz
Re: Forum Upgrade
« Reply #30 on: June 30, 2011, 19:24 »
no rush Simon
as you say it takes a while to get used to changes and im sure we've had this before
Offline Baz
Re: Forum Upgrade
« Reply #31 on: June 30, 2011, 19:27 »
what I have just noticed though is the spell check doesnt work.
Am getting the underlined mistakes but right click on the word just brings up the right click normal context menu, in Firefox,  and the spell check button does not check any thing or have any words available or so it seems
Re: Forum Upgrade
« Reply #32 on: June 30, 2011, 19:28 »
yeah, took them quite some convincing of me that we needed to change... I'm pleased with our results though.
Though you'll be happy to know we avoid the "sheep" theme that Clive wanted. But only just as I think Rik was considering it.....  :devil:
Re: Forum Upgrade
« Reply #33 on: June 30, 2011, 19:29 »
hmm - same thing for me. I'd assumed it was my firefox - its been a bit weird as of late. Maybe its the new editor - I'll investigate.
Offline Baz
Re: Forum Upgrade
« Reply #34 on: June 30, 2011, 19:32 »
sheep !!!!!!!!!!!!!
 :o :o   that would have been  BAAAAAD  :scoot:
Offline Baz
Re: Forum Upgrade
« Reply #35 on: June 30, 2011, 19:33 »
ive just tried the right click in another forum Sam and it works.I thought the same as you maybe a FF thing but not so
Offline Baz
Re: Forum Upgrade
« Reply #36 on: June 30, 2011, 19:36 »
I like the little drop downs in the top menu/tabs
Re: Forum Upgrade
« Reply #37 on: June 30, 2011, 19:36 »
but another forum running smf 2?
Offline Baz
Re: Forum Upgrade
« Reply #38 on: June 30, 2011, 19:39 »
good point  and no its not still 1.1.14
drag their heels next door they do  :o:
Re: Forum Upgrade
« Reply #39 on: June 30, 2011, 19:45 »
I thought that's where you might have gone :-)
They have a trickier situation with their upgrades, from what I can tell. We have a code base that we have kept clean and documentaed.
Re: Forum Upgrade
« Reply #40 on: June 30, 2011, 20:02 »
Baz - the spell check works in Firefox if you disable the WYSIWYG editor - you can set this in your profile settings.
It works fine in Chrome in either mode.
Re: Forum Upgrade
« Reply #41 on: June 30, 2011, 22:57 »
It doesn't work in chrome for me.   :bawl:
Re: Forum Upgrade
« Reply #42 on: June 30, 2011, 23:21 »
I've tried to disable the WYSIWYG editor, but it seems to have had no effect.  I'm not sure what we should be seeing instead.  :dunno:
Re: Forum Upgrade
« Reply #43 on: June 30, 2011, 23:55 »
it works fine for me in ff 3.6
Swiftfox 3.6
SWare iron 11.0
Chrome 11
Looks great
Re: Forum Upgrade
« Reply #44 on: June 30, 2011, 23:57 »
We're getting there!  :)
