Author Topic: Forum Upgrade  (Read 24214 times)
Re: Forum Upgrade
« Reply #60 on: July 01, 2011, 22:28 »
You can only post attachments in the General and Tech boards, not in this one, Baz.  Was there something specific?
Offline Baz
Re: Forum Upgrade
« Reply #61 on: July 02, 2011, 08:19 »
ah right that'll explain it then.
it was just a pic of my profile settings after Sam (I think) mentioned how to change something,the spell check prob.i looked and have 2 identical entries for something to do with WYSIWYG
Re: Forum Upgrade
« Reply #62 on: July 02, 2011, 09:20 »
Yes, I think we all did, but I've now reinstalled the mod, so that may be rectified, but I haven't checked yet.  There was three at one point!  ;D
Re: Forum Upgrade
« Reply #63 on: July 02, 2011, 10:16 »
... and then there were three... again!   ::)
The mod that puts the smilies in the Quick Reply box does seem a little buggy, particularly in the Chrome browser.  I  have tested it myself using Chrome, and have started a thread here:
http://www.pc-pals.com/smf/index.php/topic,35279
I have discovered that the mod is being 'adopted' by SMF themselves (currently, it's one written by an independent mod writer), and will hopefully appear by default in future forum upgrades, at which point, it should work correctly on all browsers (:x:), but until then, all we can do is use the functionality available, and work around the bits that don't quite do as we'd like them to.
Alternatively, we can uninstall the mod, but then we would lose the smilies from the Quick Reply box.
So, I guess, the question is, should it stay, or should it go?
Re: Forum Upgrade
« Reply #64 on: July 02, 2011, 13:44 »
I think smilies are more important than the url box.   :)
Offline Den
Re: Forum Upgrade
« Reply #65 on: July 03, 2011, 10:14 »
If I use chrome and click on the last post of a topic down the right hand side of the forum it takes me to the reply not the topic.  :)x
Re: Forum Upgrade
« Reply #66 on: August 09, 2011, 13:29 »
Holy cr*p, I thought I'd clicked on the wrong bookmark.... :stars:
That'll teach me for going missing for awhile.  ;)
Re: Forum Upgrade
« Reply #67 on: August 09, 2011, 13:30 »
We waited until the coast was clear...   :devil: ;)
Re: Forum Upgrade
« Reply #68 on: August 11, 2011, 13:18 »
Oh, you'll never know when I'll just pop up....   neither will I for for that matter. ;D
