Author Topic: Testing with Chrome  (Read 21090 times)
Re: Testing with Chrome
« Reply #30 on: July 03, 2011, 19:19 »
Umm....  Que?  :dunno:
« Reply #31 on: July 03, 2011, 19:53 »
Probably a linux flash bug
linux and flash dont do well together
« Reply #32 on: July 03, 2011, 22:38 »
Certainly haven't noticed that one, Dave, and I don't believe the avatars or smilies are flash.  Could it be a cache issue?  :dunno:
« Reply #33 on: July 04, 2011, 02:26 »
Don't think so it was a new install of seamonkey
Thats the only browser it did it with
The avatar as well as smileys on the popup did it
Looked as if the smileys with motion were the ones blinking
« Reply #34 on: July 04, 2011, 09:43 »
I don't know then, Dave. It didn't do it with my SeaMonkey 2.0, and I've just upgraded to 2.1, which is fine too, and the WYSIWYG editor also works in it now.
« Reply #35 on: July 04, 2011, 09:45 »
I think the smiley popup is a Java script.  Could it be that?
« Reply #36 on: July 04, 2011, 15:28 »
Its possible I just installed seamonkey to check it on the forum here
Java could have been messed up in it
All the other browsers I use are doing fine
« Reply #37 on: July 04, 2011, 16:26 »
Good to hear.  :)
« Reply #38 on: July 05, 2011, 12:06 »
In Clive's spirit of using b*****dised browsers that would seem fit.
« Reply #39 on: July 05, 2011, 12:07 »
I've not had much of an issue with flash in quite some time - occasionally I have issues with audio, but not very often.
« Reply #40 on: July 05, 2011, 12:08 »
I've just been tinkering, Clive.  I suspect we still have plenty for Sam to do.  ;)
After all your tinkering tell me where I need to fix things.
Sounds as if *reading above* we have a plan for now, but likely we have to wait until SMF fixes a few bugs.
BTW I really don't like that the quote button now just goes to the quick reply - I don't like using it. I might just disable quick reply (for me) and see if that fixes my problem with this.
« Reply #41 on: July 05, 2011, 12:42 »
Yes, it should do.
I think it's just the URL popup and the Newsfader in IE, on this theme, that are the remaining issues.  It's not that the URL popup doesn't work, it just doesn't work as we'd like.
« Reply #42 on: July 05, 2011, 12:51 »
okies
« Reply #43 on: July 05, 2011, 13:42 »
Oh, and getting the 'active' highlight on all of the top menu buttons, but that's not essential.
« Reply #44 on: July 05, 2011, 13:45 »
oh yes.
