Author Topic: Newsfader / Internet Explorer  (Read 8777 times)
« on: July 02, 2011, 10:20 »
We are aware of an issue with the index page Newsfader, which does not display correctly in Internet Explorer, and are currently working on a fix for this.
Re: Newsfader / Internet Explorer
« Reply #1 on: July 02, 2011, 12:42 »
It makes the page 'jump' when it adjusts the area to fit the height of the text, in Firefox 5 too.  Just specify a constant height for the field and you're laughing.
« Reply #2 on: July 02, 2011, 12:46 »
I'll have a look... did it do that on the old board?
Offline Baz
« Reply #3 on: July 02, 2011, 12:54 »
I noticed that what Rodders said in FF too,thought it was just a page refresh until I watched for what it actually was.Dont remember it doing that in the old board.
I have that section collapsed now so dont see it,un less of course I visit the forums as a guest and its back  :D
« Reply #4 on: July 02, 2011, 12:59 »
I've fixed the jumping by adding a set height, but does anyone (Rod?) know how to get the text vertically central if there's only one line?  This is the code, and I'm also interested in the bit where it says about the IE JS bug - what does it mean, "shouldn't be shorthand style"?  Could that be the cause of our issue?
#smfFadeScroller
   text-align: center;
   padding: 0 2em;
   height: 40px;
   overflow: auto;
   margin: 1em 0;
   color: #575757; /* shouldn't be shorthand style due to a JS bug in IE! */
Offline Baz
« Reply #5 on: July 02, 2011, 14:30 »
just a total guess  could it be the overflow:auto
if its only one line doesnt need to overflow    :dunno: :dunno:
sorry
have you tried to see what happens with more text in so it has to force into 3 or more lines
« Last Edit: July 02, 2011, 14:32 by Baz »
« Reply #6 on: July 02, 2011, 14:39 »
Three lines would produce a scroll bar, Baz.
« Reply #7 on: July 02, 2011, 16:16 »
I dunno, but keep an eye on this thread.  http://www.simplemachines.org/community/index.php?topic=440756.0 thread.
Regarding the 'shorthand' comment, it's a bit ambiguous, but the way I would interpret that is: use a value instead of the color name.
« Reply #8 on: July 02, 2011, 16:19 »
I am, it's my thread!   :laugh:
« Reply #9 on: July 02, 2011, 16:22 »
I thought the 'Si' bit sounded familiar.   ;)
« Reply #10 on: July 05, 2011, 12:14 »
did you fix it? I can fix this.
« Reply #11 on: July 05, 2011, 12:15 »
I'm guessing you did - as I don't see that behaviour here.
« Reply #12 on: July 05, 2011, 12:16 »
No.  If you use compatibility mode in IE, it works on the Default theme, but not on ours.
« Reply #13 on: July 05, 2011, 12:17 »
No I wasn't. I'll take a look this evening.
