Author Topic: What You See Is What You Get (WYSIWYG) Editor  (Read 18268 times)
« on: July 03, 2011, 12:20 »
One of the new features of the upgraded forum software is the WYSIWYG editor, which has been a little problematic for some users.  There have been issues with line spacing, formatting and Hyperlink functions, and we, the staff team, are also still trying to get used to the new feature, so we've been trying to 'fine tune' is for you, to it's best overall functionality.
It now seems that most of the time, for most users, most things function as they should, but you may like to know that there is a simple way to switch off the WYSIWYG function, on a 'per post' basis, by clicking the WYSIWYG toggle button (far right), if a post you are trying to make becomes 'problematic'.  This will revert the posting text box to the 'old' type, but functions such as the URL popup will not work, meaning that links will have to be entered manually.  The WYSIWYG function will be automatically switched back on for your next post.
Similarly, if you wish to have the WYSIWYG editor switched OFF for you, by default, and toggle it to switch ON, when required, such as for Hyperlink popup box function, you can do this in your Profile, by going to Look and Layout, and unticking the 'Show WYSIWYG editor on post page by default' option.
On the subject of posting links, these work slightly differently to before, in that to post a LINK type link, using the WYSIWYG editor, you first have to type the link title, say, PC Pals, then highlight it, and click the Hyperlink button, where pasting in your link, and clicking OK, will produce a LINK type link, rather than the full URL.
We apologise if some of these changes are confusing.  We are still learning the new forum software ourselves, which, itself, is still evolving, so I am sure that things will smooth out in time.
Please feel free to ask any questions, and we will try to help.  :)
Re: What You See Is What You Get (WYSIWYG) Editor
« Reply #1 on: July 03, 2011, 13:22 »
It's still infuriatingly glitchy for me.  As a result I could properly reply to KRO's post for more than 10 minutes, then had to settle for a kludge.  Maybe it just doesn't like more than one link per post.
« Reply #2 on: July 03, 2011, 13:25 »
I've also just replied to KRO's post, with several links.  What browser are you using, Rod?  It's a learning curve, to be sure, but I think it's just a matter of getting used to the new method of posting links.  I don't know why they couldn't have used the 'double' popup method, of Link then Title, as before, but hopefully, it will improve with forum upgrades.
Also, when Sam has the time, the 'Link then Title' method may be something he could implement.
« Last Edit: July 03, 2011, 13:27 by Simon »
« Reply #3 on: July 03, 2011, 13:27 »
I'm using FFS v5.0.  It's like Firefox, only with more harsh language.
« Reply #4 on: July 03, 2011, 13:29 »
Most things seem to work better on FF than other browsers.   :dunno:
« Reply #5 on: July 05, 2011, 12:12 »
could do something fancy, what were you thinking?
« Reply #6 on: July 05, 2011, 12:19 »
Basically, all we want is the old URL popup mod, where you click the Hyperlink button, and it asks for the link, then the link title, if you see what I mean.
« Reply #7 on: July 05, 2011, 12:23 »
but the site already does that. It does it well. Its worked for me in Chrome and firefox. No WYSIWYG on though. And I'm not using the quick reply. That's the other issue. I can't replicate it not working otherwise though.
« Reply #9 on: July 05, 2011, 12:31 »
did  you turn off the WYSIWYG editor?
Also that bread doesn't look too good. Next time you try a link make sure I get a good view of something I want.
« Reply #10 on: July 05, 2011, 12:34 »
Actually it's delicious!   :P
« Reply #11 on: July 05, 2011, 12:49 »
How would you usually create a LINK type link, Sam, rather than the full URL?
« Reply #12 on: July 05, 2011, 12:53 »
by manually typing the code.
« Reply #13 on: July 05, 2011, 12:53 »
that being that, but did you turn of the thingy?
« Reply #14 on: July 05, 2011, 13:06 »
Yes, it's off.   :D
