Author Topic: Could Linux help?  (Read 6650 times)
Could Linux help?
« on: July 04, 2011, 11:21 »
A friend has a hard drive where Windows is on the C partition, and Documents on the D partition.  Windows is knackered, and the C drive is so full that it has less than 200mb disc space left, and the computer basically won't function.
Would booting from a Linux CD enable them to recover their data on the D partition, to an external hard drive?  If so, how exactly is this done?
Alternatively, could they boot from a Windows CD, delete the C partition and reinstall Windows, without putting the data on D drive at risk?  Could they also expand the C partition this way, and again, would this put their data at risk?
I'm not getting involved with this one, other than to offer advice!
Re: Could Linux help?
« Reply #1 on: July 04, 2011, 13:27 »
Why not just mount the drive in an external enclosure on another box and backup/delete out some of the crap from the ailing HDD?  Then you can do a windows repair once you've got some breathing space.
« Reply #2 on: July 04, 2011, 13:29 »
Because they haven't got an enclosure or another box, and I'm not taking mine to bits!  ;)
« Reply #3 on: July 04, 2011, 13:31 »
What kind of computer-mender-man are you?   :o
« Reply #4 on: July 04, 2011, 13:31 »
The current plan is to use an external USB drive to try to save some of the essential data, then to format and reintall Windows.
« Reply #5 on: July 04, 2011, 13:32 »
One that's tired of spending my free time on other people's machines!  ;D
« Reply #6 on: July 04, 2011, 13:34 »
The current plan is, of course, reliant on Windows being able to wheeze it's way through the process, without completely croaking.
« Reply #7 on: July 04, 2011, 13:37 »
I know the feeling.  On the other hand, I've just had my car valeted to showroom standard in exchange for sorting someone's laptop.   8-)
« Reply #8 on: July 04, 2011, 13:46 »
Nice trade.  :)
« Reply #9 on: July 04, 2011, 15:07 »
Make a copy of Puppy live cd
Use it to put all the info on a disc
When the live cd opens all drives should be mounted
Its basically an easy process once the info is saved on a disc
You can do anything you want with the hard drives
Repair the windows install or a complete reinstall
Puppy
http://is.gd/hNpqt7
« Reply #10 on: July 04, 2011, 16:27 »
Thanks Dave.
« Reply #11 on: July 04, 2011, 16:59 »
Your welcome Simon
Its what i use for all repairs and virus removal on all my friends windows installs
« Reply #12 on: July 04, 2011, 17:30 »
I have a HDD partitioned between Windows Vista and Ubuntu.  Could I use a live CD to remove Ubuntu and free up more space for Vista?
« Reply #13 on: July 04, 2011, 17:50 »
Yes use gparted in puppy to delete ubuntu then use it to expand the windows partician
then you have one of two choices either install grub with puppy or use a windows disc and repair windows mbr
Windows mbr will be messed up when you remove ubuntu so it will need to be repaired before you can log in
« Reply #14 on: July 04, 2011, 18:26 »
What about the data on the D partition of my friend's drive, Dave?  If I use Gparted to expand the C drive, does that not put the other data at risk, given it's all on one physical drive?
