Quote:
A friend has a hard drive where Windows is on the C partition, and Documents on the D partition. Windows is knackered, and the C drive is so full that it has less than 200mb disc space left, and the computer basically won't function.
Ill start over I didn't make it very clear
Use puppy to retrieve all data from D partition to hard drive,cd,dvd or flash drive
all you need to do is copy and paste to retrieve the data
copy from D partition to either desktop or a CD,dvd or external drive which will be shown in puppy
All mounted up drives will show in puppy and you can move data back and forth
Use gparted to either delete or re size D partition
If the windows installation is in working order other than not having enough space
Use gparted to resize C partition
You have already saved the data on D partition
So you can either delete it or resize it to make room for C partition
I hope i made that more clear im not used to giving directions more used to doing it lol
