Author Topic: Researchers create "defibrillator" for stalled software  (Read 1493 times)
It's a common scenario: a co-worker starts screaming obscenities at a computer because it stalled in the middle of something important.
Researchers at MIT believe they have found a way to fix stalled software without losing work, which they're calling a defibrillator for hung applications.
One major cause of stalled software is infinite loops - when applications execute a single bit of code over and over again. To get out of that frustrating cycle, researchers have created a tool called Jolt that interrupts those infinite loops, pushing the software onto the next line of code.
Jolt looks out for infinite loops by monitoring memory use, taking a series of "snapshots" after each loop.
“The snapshots could be completely different,” explains researcher Michael Carbin. “That can be an indicator that your program is computing. It may be doing something useful for you, so maybe you don’t want to break out of this. But if it’s not, and it has exactly the same state, then clearly it’s stuck in an infinite loop.”
Using Jolt, the researchers have restored five different programs, leaving them stable enough to save work and restart.
Read more: http://www.pcpro.co.uk/news/369076/researchers-create-defibrillator-for-stalled-software
Re: Researchers create "defibrillator" for stalled software
« Reply #1 on: August 03, 2011, 07:47 »
hmm...
« Reply #2 on: August 03, 2011, 09:56 »
My thoughts entirely, Sam. The overheads must be huge.
« Reply #3 on: August 03, 2011, 15:05 »
But how we would all love it to work!   :laugh:
« Reply #4 on: August 03, 2011, 15:52 »
What we'd really like is for Windows to work. ;D (Cue Sam...)
« Reply #5 on: August 03, 2011, 17:33 »
and it should. If you want an operating system to just work then you are barking up the wrong tree.
« Reply #6 on: August 03, 2011, 18:32 »
Woof. ;D
« Reply #7 on: August 03, 2011, 19:00 »
« Reply #8 on: August 03, 2011, 22:07 »
not quite the get ubuntu response you were after, eh?
« Reply #9 on: August 03, 2011, 22:36 »
I think he was baiting you, Sam.  ;D
« Reply #10 on: August 04, 2011, 07:05 »
Never.
