April 19, 2025, 18:23
Technical Help & Discussion
AV Lounge
Improving DAB Radio Reception
Topic: Improving DAB Radio Reception (Read 23879 times)
GillE
Never totally serious
August 03, 2011, 15:02 »
I have an old DAB radio which can receive all the stations I want to hear with no problem. I've also got a newer DAB radio which cannot receive all the stations I want hear, even when it is placed in the same location as the old one. However, I want to use the newer radio because it has other accessories such as an iPod dock, CD player and USB/card input.
The principle difference between the two radios that I can see is the old one has a 'proper' extendible and multidirectional aerial whereas the newer one just has a bit of wire sticking out its back. Is there any way to improve the newer radio so that I can receive more stations?
(Schopenhauer,
Die Kunst Recht zu Behalten
Re: Improving DAB Radio Reception
August 03, 2011, 15:09 »
Not a very elegant solution Gill, but try extending the aerial by adding more wire. In the olden days that was normal practice for picking up Radio Luxembourg.
August 03, 2011, 15:50 »
I also have two like that, Gill, and find the same problems, but as long as they can both pick up Radio 2 and Planet Rock, I'm happy.
August 03, 2011, 17:36 »
some of these docs do come with a little and quite often well hidden port to attach and aerial too. What is the make?
GillE
August 03, 2011, 18:06 »
It's an Hitachi AXM209UK Slim DAB Micro System with docking for iPod. I've got the instruction manual in front of me and I can't see another aerial socket on the parts diagram, nor can I see one on the actual radio itself.
(Schopenhauer,
August 03, 2011, 19:02 »
Why is it an Hitachi, but a hospital?
August 03, 2011, 20:13 »
Damn phone.
August 03, 2011, 20:44 »
The other inelegant solution Gill is to attach the tiny aerial tail to an aluminium dish (that's why they invented blu-tak) and that will act as a satellite dish and amplify the signal. Sadly these techniques really do work so there is no excuse to take a sledgehammer to the thing and smash it into tiny pieces.
August 03, 2011, 22:16 »
maybe there is some interference from the power supply, bet it was put in some silly place.. like next to the antenna.
Reply #9 on:
August 03, 2011, 22:54 »
Quote from: Clive on August 03, 2011, 20:13
Damn phone.
No, it was a serious grammar question.
They both begin with H, so why AN Hitachi, not A Hitachi?
Reply #10 on:
August 03, 2011, 22:57 »
Oh I see what you mean. Good question.
GillE
Reply #11 on:
August 03, 2011, 23:13 »
'H' is pronounced 'Aitch'. Cue
Pedants Corner
(Schopenhauer,
Reply #12 on:
August 03, 2011, 23:24 »
That wasn't the question.
It's to do with the pronoun (?). You say "She's had
a
hysterectomy", not
AN
hysterectomy. You say, "It's
AN
honour", not
a
honour, but that's presumably because the 'Aitch' is silent. So, I'm not saying it's incorrect, but why
AN
Hitachi, not
A
Hitachi, and why
A
hospital, not
AN
hospital? This will keep me awake tonight!
Reply #13 on:
August 04, 2011, 07:00 »
I think I'd say an eventhough its probably wrong. I think I mix between the two with the 'aitch'
Reply #14 on:
August 04, 2011, 10:24 »
It's called English, Simon, it has a lot of quirks. Usually, the a/an, is based on the sound of the first syllable of the word it precedes. It should be an hotel, though, for example.
AV Lounge
