Author Topic: Improving DAB Radio Reception  (Read 23138 times)
Online Simon
Re: Improving DAB Radio Reception
« Reply #30 on: August 04, 2011, 22:29 »
« Reply #31 on: August 05, 2011, 01:17 »
I might tie the end around a metal coat hanger  :dunno: .
« Reply #32 on: August 05, 2011, 10:02 »
« Reply #33 on: August 05, 2011, 10:23 »
That should work quite well.  It was standard practice for seventies cars.   ;D
Online Simon
« Reply #34 on: August 05, 2011, 10:47 »
I had one on my Ford Capri!  ;D
« Reply #35 on: August 05, 2011, 10:56 »
Isle bet.  ;D
Online Simon
« Reply #36 on: August 05, 2011, 11:18 »
Bit early.  Was only 13 then.  ;)
« Reply #37 on: August 05, 2011, 11:21 »
« Reply #38 on: August 05, 2011, 13:04 »
It works  :) !
The reception is weak so I will probably lose the signal now and then, but the metal coat hanger solution is working fine at the moment.
Online Simon
« Reply #39 on: August 05, 2011, 13:05 »
« Reply #40 on: August 05, 2011, 14:02 »
Use the aluminium tray as well and you can store fresh herbs in it too.
Online Simon
« Reply #41 on: August 05, 2011, 15:38 »
Or go sledging.
« Reply #42 on: August 05, 2011, 16:45 »
You only need to be able to speak to do that. :)
« Reply #43 on: August 08, 2011, 10:46 »
Yep.
