Author Topic: Firefox not working properly!on my Main PC.  (Read 2052 times)
Offline TOFFEEMAN1878
« on: August 22, 2011, 22:48 »
Until I stop Scripts, also a message tells me to reinstall the Toolbar! how do I reinstall it?
Re: Firefox not working properly!on my Main PC.
« Reply #1 on: August 22, 2011, 23:04 »
Hi Jim,
Firstly, what version of Firefox are you running, and what add-ons do you have?  I suspect everything just needs to be updated, or possibly one of your add-ons isn't compatible with the latest version of Firefox.
« Reply #2 on: August 22, 2011, 23:11 »
Hi Simon , I have disabled all add ons & it still wont work properly, I think the version is Firefox 6, I have tried downloading new copies ,but still get the same results. I'm running Firefox 7 beta on my laptop.
« Reply #3 on: August 22, 2011, 23:14 »
What exactly is it doing?
« Reply #4 on: August 22, 2011, 23:35 »
Simon, when I click on the Firefox logo it takes an eternity to launch the window with Stop Script button,then when Firefox opens there is a message in the navigation bar " Firefox was not able to load Toolbar reinstall Toolbar"
« Reply #5 on: August 22, 2011, 23:50 »
OK, if you've removed all the Firefox add-ons, it must be referring to another toolbar.  If you've any idea what that might be, I'd try uninstalling it, and if it isn't essential, don't reinstall it.  I'm not a fan of third party toolbars, as they tend to clutter up the viewing area, and can also change your settings, or contain spyware.
« Reply #6 on: August 23, 2011, 17:00 »
Hi Simon, It appears not all of the extensions were stopped,it turned out to a AVG Toolbar in Extensions .....Jim :thumb:
« Reply #7 on: August 23, 2011, 17:19 »
Thanks for letting us know, Jim.
