Author Topic: Strange white lines on my screen  (Read 8227 times)
« on: September 21, 2011, 13:37 »
For the past two days I've been getting strange white lines - the size of the thin white border over the top of "PC Pals Forum".  There are usually only one or two lines and they are not there all the time.  Any idea what might be the cause?   :dunno:
Re: Strange white lines on my screen
« Reply #1 on: September 21, 2011, 13:52 »
Dead pixels?  They may not show all the time, depending on the screen background.  :dunno:
« Reply #2 on: September 21, 2011, 16:24 »
Download and run this, Clive:
http://majorgeeks.com/Undead_Pixel_d4836.html
It will show if you've got any pixel problems. I'd guess at a video driver issue myself, though - unless, of course, you've been using the Tippex again. ;)
« Reply #3 on: September 21, 2011, 20:16 »
Neat site Rik.  I've downloaded and run the software and can confirm there are no dead pixels at all! Considering this Ilyama monitor is prehistoric I'm quietly pleased.  But I downloaded and ran the outdated driver site it advertised and I have a lot of "ancient" drivers.  Unfortunately they want money to update them for me.
« Reply #4 on: September 21, 2011, 22:26 »
I'm sure you could find the drivers free, Clive.  Have you tried the Ilyama web site?  I'm a little sceptical that it could be a driver issue, though, if the fault is intermittent.  Next time it happens, can you post a screenshot?
« Reply #5 on: September 21, 2011, 22:28 »
Yes, I can do that.   8-)
« Reply #6 on: September 22, 2011, 09:58 »
A screenshot won't actually show what the monitor is displaying, rather, what the graphics card is telling it to display. If, therefore, the lines are there on the screen, but not in the screenshot, the monitor is faulty. OTOH, if it's there on both, it's the card or driver. If the machine shares main memory with graphics - only likely on a notebook normally - you'd have to check memory as well.
« Reply #7 on: September 22, 2011, 12:00 »
Today there is no problem with it.  :dunno:
« Reply #8 on: September 22, 2011, 12:12 »
Watch that space. :)
« Reply #9 on: September 22, 2011, 13:42 »
Strangely my mouse was playing up yesterday too.  But I spilt coffee all over it.  It works fine today!   :)x
« Reply #10 on: September 22, 2011, 13:45 »
« Reply #11 on: September 22, 2011, 16:18 »
I was too hasty ordering a new one from Amazon!  A fiver for the mouse and almost the same for post and packing!    >:(
« Reply #12 on: September 22, 2011, 16:56 »
Buy them in fives from Misco, Clive, they're much cheaper in OEM packs.
« Reply #13 on: September 22, 2011, 19:39 »
This one has lasted 5 years and is set to go on and on... ;D  In 25 years time I shall be er...25 years older.   ;D
