Author Topic: Hard drive woes  (Read 11491 times)
Hard drive woes
« on: December 13, 2011, 17:35 »
I suspect my hard drive on my main computer has packed in.  When I tried to boot it up this morning it only got as far as the "Loading Windows" screen and then stopped with an error message to say Windows had not loaded properly.  A strange clicking noise could be heard coming from the case.  I've taken it to my usual repair shop and they suspect the stepper motors on on the HDD have failed and I will need a new one.  They were supposed to be taking a look at it and leaving a message on my answer phone this afternoon but I've not heard anything yet.    :cry:
Re: Hard drive woes
« Reply #1 on: December 13, 2011, 17:46 »
If it's getting that far, Clive, my instinct would be a bad sector.
Online Simon
Re: Hard drive woes
« Reply #2 on: December 13, 2011, 19:01 »
Have you got your data backed up, Clive?
Re: Hard drive woes
« Reply #3 on: December 13, 2011, 20:43 »
Er...  yes.  I have Acronis but my last backup is several months old.   :blush:  Still, it's much better than nothing at all!
Online Simon
Re: Hard drive woes
« Reply #4 on: December 13, 2011, 22:33 »
Well, sorry to hear of your troubles, but thanks for reminding me to do a long overdue backup!
Re: Hard drive woes
« Reply #5 on: December 13, 2011, 22:46 »
A wise decision Simon!   8-)
Re: Hard drive woes
« Reply #6 on: December 14, 2011, 09:04 »
could you set it up to do daily incremental backups with that? schedule it and never worry?
Re: Hard drive woes
« Reply #7 on: December 14, 2011, 09:12 »
Or invest in a Clickfree external USB drive, which does an automatic incremental backup (of several machines) just by plugging it in.
Re: Hard drive woes
« Reply #8 on: December 14, 2011, 13:17 »
That sounds a very good idea!  I'll look into that possibility.
Online Simon
Re: Hard drive woes
« Reply #9 on: December 14, 2011, 13:54 »
Does 'incremental' mean that it only updates files that haven't changed, or new ones added?  One reason I don't do them very often is that it takes so long overwriting everything from the previous backup.
Re: Hard drive woes
« Reply #10 on: December 14, 2011, 16:04 »
Yes, incremental backups are just the changes from the last backup.
Re: Hard drive woes
« Reply #11 on: December 14, 2011, 16:37 »
The repair shop has replaced the 80 Gb hard drive  with a 200 Gb.  They asked me for my external drive and also my Acronis discs and confirm that my full backups were successful.  But they are having problems transferring it to the new drive.   :dunno:
Re: Hard drive woes
« Reply #12 on: December 14, 2011, 16:54 »
The Acronis b/u stores the MBR if I am right, Clive, so it gets upset when the HD changes. They should be able to open the backup and copy files manually if that's the case.
Re: Hard drive woes
« Reply #13 on: December 14, 2011, 17:28 »
Ah right!  They said that they could do that if all else fails.  When I left them they were trying to transfer the backup to a spare HDD and then transfer it from that to my new HDD.  Interestingly, they said that I am the first customer to have ever taken a mirror image of their HDD and were most impressed.  Doesn't seem to have done me much good though!   ::)
Re: Hard drive woes
« Reply #14 on: December 15, 2011, 08:17 »
You can't beat mechanical failure, Clive, that's why we backup, don't we Simon.  :devil:
