Author Topic: Hard drive woes  (Read 12107 times)
Re: Hard drive woes
« Reply #30 on: December 15, 2011, 18:18 »
Oh I have the discs.  But it will only give a very limited installation if you have used up all your lives.  TBH I'm better off loading Office 2000 which does not have any restrictions on the number of times it can be  downloaded.  ::)
Re: Hard drive woes
« Reply #31 on: December 15, 2011, 18:23 »
You can usually overcome the restrictions with a phone call, Clive.
Re: Hard drive woes
« Reply #32 on: December 15, 2011, 18:25 »
OK, I'll give it a try.
Re: Hard drive woes
« Reply #33 on: December 15, 2011, 22:56 »
Things are going fine so far and I've now reinstalled all my drivers and a lot of software.  Some things that didn't get backed up were my e-mail addresses and bookmarks.   :cry:  It's going to be a long haul.
Re: Hard drive woes
« Reply #34 on: December 15, 2011, 22:57 »
Ouch!  Those are what I'd miss most.  :(  How come the Acronis software didn't save them?
Re: Hard drive woes
« Reply #35 on: December 16, 2011, 10:20 »
you should use chrome and save it too your google cloud.
Re: Hard drive woes
« Reply #36 on: December 16, 2011, 10:46 »
Acronis  leaves a lot to be desired so don't count on it. It didn't save my contacts nor my bookmarks which I have to find all over again.   :bawl:  I rescued some of my contacts from a backup onto a CD.
Re: Hard drive woes
« Reply #37 on: December 16, 2011, 10:46 »
I have a GMail address Sam and save some stuff onto that.
Re: Hard drive woes
« Reply #38 on: December 16, 2011, 11:21 »
What drive letters were you using, Clive?
Re: Hard drive woes
« Reply #39 on: December 16, 2011, 15:27 »
I think the back-up drive was F.
Re: Hard drive woes
« Reply #40 on: December 16, 2011, 17:22 »
Contents and bookmarks are stored on C, so unless you backed that up, those files would be missing.
Re: Hard drive woes
« Reply #41 on: December 16, 2011, 18:34 »
Sorry Rik, I thought you were asking for the letter of the external drive which contained the C drive image.
Re: Hard drive woes
« Reply #42 on: December 17, 2011, 10:55 »
Windows would normally assign the next available drive letter to the external HD, what drives were allocated to D & E?
Re: Hard drive woes
« Reply #43 on: December 17, 2011, 11:44 »
CD Rom and memory stick. The memory stick was of more value than Acronis and had backed up stuff without me even knowing about it.   8-)
Re: Hard drive woes
« Reply #44 on: December 17, 2011, 11:48 »
If Acronis imaged the C drive, the files should be there, Clive. They certainly are on my backups.
