Author Topic: Java  (Read 3617 times)
Java
« on: December 16, 2011, 20:55 »
It seems I require Java in order to use a piece of bespoke software.  For some reason, since my rebuild, I no longer have it installed on my machine.  Where would be the safest place to download it?
Re: Java
« Reply #1 on: December 16, 2011, 21:00 »
The best and safest for windows
http://is.gd/PLXAPx
Re: Java
« Reply #2 on: December 16, 2011, 22:42 »
Thanks Davy - that worked a treat.  It's a small application that allows me to remotely view a spectroscope located about 250 miles from where I live.  All very clever.   8-)
Re: Java
« Reply #3 on: December 16, 2011, 22:47 »
Your Welcome
A lot of the other sites its listed on are infected
if you need an older version let me know i think i have access to them
Re: Java
« Reply #4 on: December 16, 2011, 22:58 »
Yes, I'd heard about that Davy.  I'm always loathe to download anything like that from a Google search.
Re: Java
« Reply #5 on: December 16, 2011, 23:18 »
Very few sites are safe to download from anymore
Have to be able to check the download before you do
Re: Java
« Reply #6 on: December 16, 2011, 23:36 »
Or just go to the source - I'm on phone so not sure where your link points to but I'm sure java.com is the place to go
Re: Java
« Reply #7 on: December 16, 2011, 23:36 »
Though yeah lots of caution required
Re: Java
« Reply #8 on: December 17, 2011, 00:18 »
Thats where i sent him Sam
Re: Java
« Reply #9 on: December 17, 2011, 09:39 »
thought you would have :-)
Re: Java
« Reply #10 on: December 17, 2011, 11:41 »
Thanks Sam.
