Author Topic: Inverted Commas  (Read 2827 times)
Offline hitanykey
Inverted Commas
« on: December 24, 2011, 11:10 »
Inverted commas in jokes appear as " Which makes reading them aloud to my other half more difficult.  Can I make this appear as inverted commas somehow. Only recently started again so may have missed this elsewhere but searching gives no clues.
Re: Inverted Commas
« Reply #1 on: December 24, 2011, 11:11 »
depending on what you are doing you could do find and replace. """ - what are we looking at specifically - I mean what programme are you using?
Offline hitanykey
Re: Inverted Commas
« Reply #2 on: December 24, 2011, 11:23 »
Hi Sam,
 I am just reading the blonde jokes on the comedy page of this forum. I have not encountered this problem on Idnetters comedy where they appear as they should. Using FF latest , Win7 home premium.
Re: Inverted Commas
« Reply #3 on: December 24, 2011, 11:28 »
That's odd, we're both using the same version of the forum software. :dunno:
I see what you mean, though, and looking at the age of the posts, I suspect that something was 'lost in translation' when the forum software used here was changed to SMF.
Re: Inverted Commas
« Reply #4 on: December 24, 2011, 11:33 »
Yes, some very old posts have this character issue.  I don't think there's much we can do about it now, unless Sam can come up with a quick fix.
Re: Inverted Commas
« Reply #5 on: December 24, 2011, 11:35 »
hmmm, I can probably come up with a fix on the database - would involve me running a script to find and replace on all entries...
Re: Inverted Commas
« Reply #6 on: December 24, 2011, 11:36 »
I don't know, Simon, you could manually edit all the affected posts.  :devil: :scoot: :santa:
Re: Inverted Commas
« Reply #7 on: December 24, 2011, 11:36 »
though alas it won't be a quick job - just had a look at what I'll need todo - so it will have to wait for now - sorry - I'll try and do this in the new year - but someone give me a push if I haven't. Actually if anyone notices any other old - as Rik calls them "lost in translation bugs" let me know. It is indeed likely when we changed forum software that a few strings weren't properly copied over.
Re: Inverted Commas
« Reply #8 on: December 24, 2011, 11:39 »
Why don't we delegate fixing it manually to Clive, he's not here to object. All in favour, raise your hands.  ;D :wave:
Re: Inverted Commas
« Reply #9 on: December 24, 2011, 12:12 »
here here!
Re: Inverted Commas
« Reply #10 on: December 24, 2011, 12:14 »
Two down, where's Simon when you need him.  ;D
Re: Inverted Commas
« Reply #11 on: December 24, 2011, 12:18 »
Aye!  :thumb:
Re: Inverted Commas
« Reply #12 on: December 24, 2011, 12:20 »
Majority! Clive, it's all down to you.  :laugh:
Re: Inverted Commas
« Reply #13 on: December 24, 2011, 14:51 »
I fixed hundreds of those &quot's some years ago but realised there were just far too many to deal with and lost the will to live.   ;D
Re: Inverted Commas
« Reply #14 on: December 24, 2011, 15:20 »
