Author Topic: A bit backwards  (Read 627 times)
A bit backwards
« on: January 17, 2012, 18:36 »
A tourist in Vienna is going through a graveyard and all of a sudden
he hears music. No one is around, so he starts searching for the
source. He finally locates the origin and finds it is coming from a
grave with a headstone that reads "Ludwig van Beethoven, 1770-1827".
Then he realizes that the music is the Ninth Symphony and it is being played backward!
Puzzled, he leaves the graveyard and persuades a friend to return with him.
By the time they arrive back at the grave, the music has changed. This
time it is the Seventh Symphony, but like the previous piece, it is
being played backward.
Curious, the men agree to consult a music scholar. When they return
with the expert, the Fifth Symphony is playing, again backward.
The expert notices that the symphonies are being played in the reverse
order in which they were composed, the 9th, then the 7th, then the 5th.
By the next day the word has spread and a crowd has gathered around
the grave.
They are all listening to the Second Symphony being played backward.
Just then the graveyard's caretaker ambles up to the group.
Someone in the group asks him if he has an explanation for the music.
"I would have thought it was obvious" the caretaker says.
"He's decomposing."
Re: A bit backwards
« Reply #1 on: January 17, 2012, 18:48 »
Re: A bit backwards
« Reply #2 on: January 17, 2012, 19:50 »
 :aarrgh:
Online Simon
Re: A bit backwards
« Reply #3 on: January 17, 2012, 21:42 »
:sigh:
Re: A bit backwards
« Reply #4 on: January 18, 2012, 11:33 »
 :bawl:
Re: A bit backwards
« Reply #5 on: January 18, 2012, 11:38 »
Why thank you, Sam. ;D
