Author Topic: Control Panel  (Read 5956 times)
Offline Big_Boss
Control Panel
« on: May 15, 2003, 22:00 »
Simple question for you all, i hope  ???
On xp, I want to change my control panel to classic view, but i cant find the button  :(
I think its probably me being thick but if you can help, it would be most appreciated.
Boss
Offline Camstop
Re:Control Panel
« Reply #1 on: May 15, 2003, 22:07 »
Just click on the views button...Beside folders on mine....(Y)
Re:Control Panel
« Reply #2 on: May 15, 2003, 22:09 »
On mine, when you open control panel "switch to classic view" is in the first column on the left hand side, just under "control panel"
Offline Big_Boss
Re:Control Panel
« Reply #3 on: May 15, 2003, 22:15 »
This is what it looks like on mine:  :(
Re:Control Panel
« Reply #4 on: May 15, 2003, 22:19 »
On mine BB I just open the Control Panel and it has the option in the top section of the left hand side (Is your bit expanded or closed so you cant see it maybe? ).
This allows you to select either Classic or Custom View  :-*
Offline Camstop
Re:Control Panel
« Reply #5 on: May 15, 2003, 22:19 »
Well on mine it's here....
Offline Big_Boss
Re:Control Panel
« Reply #6 on: May 15, 2003, 22:22 »
Im pretty sure it used to be there, but it isnt now  ???
Dont know what ive done  :(
Ive checked the view menu etc and i cant see anything that relates to it.
Boss
Re:Control Panel
« Reply #7 on: May 15, 2003, 22:28 »
Click on the SEE ALSO part BB its closed up as I suggested in my prior post  :-*
Offline Big_Boss
Re:Control Panel
« Reply #8 on: May 15, 2003, 22:31 »
When i do that i get this:  :-\
Re:Control Panel
« Reply #9 on: May 15, 2003, 22:36 »
BB WATCH MY LIPS  ;D
You have clicked on OTHER OPTIONS you need to click above that on the SEE ALSO the double arrow on the top right side of that box  :-*
Re:Control Panel
« Reply #10 on: May 15, 2003, 22:39 »
No, I don't think that's it Sandra.  The See Also menu is the one that he's got.  He's missing the Control Panel menu, which is above that one, as per screenshots.  Mine is the same so I won't put mine up as well.   ;D
Can't think of an answer to this one yet, BB.   :(
Offline Big_Boss
Re:Control Panel
« Reply #11 on: May 15, 2003, 22:39 »
I have clicked on that, it just hides those 3 2 options as shown in this screen-shot
If im wrong again, dont shout at me  ;D
Boss
Offline lobo
    • http://www.burnleywood.com
Re:Control Panel
« Reply #12 on: May 15, 2003, 22:40 »
@Big_Boss
This may help,
To change the display settings from the normal start menu to the classic (old style) menu right click on the task bar at the bottom of the screen, select Properties, Start menu, Classic start menu.  To change back just click Start Menu
Brian :)
Homer   , The Odyssey, line 1
Re:Control Panel
« Reply #13 on: May 15, 2003, 22:43 »
OK, I still don't know where your button has gone, BB, but if you click Tools > Folder Options, you can choose to Use Windows Classic Folders, and that will do it, but it might also do it for all folders, not just the Control Panel.  Give it a try, you can always change it back.   :)
Offline Big_Boss
Re:Control Panel
« Reply #14 on: May 15, 2003, 22:43 »
Aww  :(
Must be one of those wierd XP thingys
Boss
