Author Topic: Moving computer settings  (Read 2000 times)
Offline Den
« on: February 13, 2012, 20:58 »
What is the best way to move settings and files etc' from my old (W7 32b) computer to me new (W7 64b) computer?
Re: Moving computer settings
« Reply #1 on: February 13, 2012, 21:17 »
There used to be a thing called File and Settings Transfer Wizard on older Windows versions, but now, I think it's called Windows Easy Transfer.  Not having used Windows 7, I have no idea if it works in the same way, but I would assume it does.
« Reply #2 on: February 14, 2012, 21:26 »
I'd make a backup copy too by just copying over all your disk on to some external drive.
« Reply #3 on: February 14, 2012, 23:14 »
Indeed, but presumably, the transfer process only copies the files, so they would still remain on the old machine as well.
« Reply #4 on: February 15, 2012, 07:25 »
yeah presumbly - I can't say I've ever done that with windows. I just copy files over with a usb disk these days.
« Reply #5 on: February 15, 2012, 11:25 »
I think that's probably what I would do, but I also think that the transfer wizard might install programs for you as well (although, not sure of that).
