July 03, 2024, 04:23
Technical Help & Discussion
General Tech Discussion, News & Q&A
TomTom
Topic: TomTom (Read 1390 times)
Den
TomTom
March 03, 2012, 20:00 »
Any thoughts on this would be nice.
My TomTom voices has gone all distorted and is now even more unpleasant to listen to than it was. I can't remember if this happened after I did a update on the software or if it just went after I turned it on to use. Help!
Re: TomTom
March 03, 2012, 20:06 »
I've never used a TomTom, sorry Den. Is there a way to reset it, or reinstall the update?
Re: TomTom
March 04, 2012, 10:58 »
You can factory reset it, press and hold the power switch iirc.
Delgado
Established Member
Re: TomTom
March 14, 2012, 07:55 »
If you factory set it while out on a journey, does it take you back where you started from?
Re: TomTom
March 14, 2012, 10:37 »
No, it takes you back to where you bought it.
Delgado
Established Member
Re: TomTom
March 14, 2012, 18:17 »
Quote from: Simon on March 14, 2012, 10:37
TomTom
