Author Topic: Those Pesky Capacitors  (Read 1205 times)
Offline Robotochan
« on: May 18, 2003, 17:20 »
Anyone else got pesky capacitors on their cheap motherboards right in the way of their AGP slot? Doesn't really bother me since my new one will come next week but was just wondering  :)
b]Oxymoron: [/b]
Example:
Microsoft Works
Re:Those Pesky Capacitors
« Reply #1 on: May 18, 2003, 17:29 »
Havent got that problem on mine but I cant remove my Ram from the first slot if my AGP card is in place as the clip wont move far enough  :o
I think they must have designed it initially thinking of putting SDRAM in and then extended the slots to take DDR  ::)
Offline Robotochan
« Reply #2 on: May 18, 2003, 19:02 »
Your probably right there. I think it's unfair how so many people see these cheap motherboard with built in everything hoping just to upgrade the GFX card so they can play their favourite games to find out 1 or more capacitors are in the way. I've unfortunatly done this twice  :-X first time my 500Mhz Celeron fried along with my mobo, ram, floppy drive and modem  :-\ 2nd is my new PC. They should put a large warning sign on the boxes and sites that sell them:
WARNING: NOT FOR PEOPLE WHO WANT TO PLAY GAMES WHICH REQUIRE A GRAPHICS CARD WHICH WILL PLAY GAMES MORE DETAILED THAN PONG!
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline ketamininja
« Reply #3 on: May 19, 2003, 11:31 »
Yes, I've notocied this on a lot of mainboards.
You usually find these problems on revision 1.0 of mainboards, and after deployment, the manufacturer finds the sales are good, so spends time changing the architecture of the board for newer revisions.
Sometimes you can get annoying onboard connector right in the way of a PCI slot.... GRRRRR  :doh:
Offline Robotochan
« Reply #4 on: May 19, 2003, 16:24 »
I just want to rip the damn things out and send PC Chips and Matsonic them in bits!!!!!
b]Oxymoron: [/b]
Example:
Microsoft Works
Offline ketamininja
« Reply #5 on: May 19, 2003, 17:23 »
always spend some more money (like an extra £10) and go for a Gigabyte or .... hmmmn iWill
NEVER NEVER go for pccips - and matsonic  :-\ not my boards at all
