Author Topic: Screen saver or not  (Read 2202 times)
Screen saver or not
« on: May 19, 2003, 18:41 »
Hi all... ;D  only me
Right.. not a big problem just a little niggle to get your heads round.
Screen saver or not, over the past few months my screen saver clicks in after 10 mins and a display comes up with what I have set...right following this  ;D well some times not all the time it sets like a power saver in the power saving settings and the VDU switches off.
Well I have checked all settings in power saver and all set to do nothing  :o  why then do the screen switches off.
Like I said only a small niggle  8) I'm in charge of this computer right... wrong  :'(
Hookstar
Ps I have searched this pc all over, might be a simple thing might be one of those weird alien things  ;D
Re:Screen saver or not
« Reply #1 on: May 19, 2003, 19:01 »
Have you checked in the BIOS or just in XP settings Hook ?
It could well be the setting in BIOS that needs changing to how you want  :-*
« Reply #2 on: May 19, 2003, 19:08 »
Sometimes I hate woman that think so logical  ;D will check it later when I log out and back in  ;) thank you  :-*
« Reply #3 on: May 19, 2003, 19:11 »
So let me get this right Hookstar. What you are saying is that whether you set a screensaver or set the screensaver as "none", it still comes on after 10 mins?
I doubt if this has anything to do with the BIOS as XP will override BIOS power management settings.
What happens if you set the power scheme option to "Always On"?
« Reply #4 on: May 19, 2003, 19:18 »
Adept, started typing.. it all out.. picture tells a thousand words.
« Reply #5 on: May 19, 2003, 19:21 »
Hmmm... Maybe Sandra is right then (damn! :P))
I can't see any other reason for it :-[
« Reply #6 on: May 19, 2003, 19:25 »
Sorry Adept,I will wait until you have had first goes next time  ;D ;D ;D
« Reply #7 on: May 19, 2003, 19:34 »
:shuddup: just wait - you may be wrong  ::) ;D :P
« Reply #8 on: May 19, 2003, 19:39 »
Well for what its worth  :D it doesnt always happen.. screen saver cuts in sometimes and some times VDU powers off..........so you might be both right  ;)
Im sitting on the fence here  :clever:
« Reply #9 on: May 19, 2003, 19:50 »
Youre not logging in on two different user accounts from time to time are you Hook,with different settings for each  ???
« Reply #10 on: May 19, 2003, 19:56 »
No Sandra.. same account..................I can be the only one on here all night  :baad: the rest dont get a chance  ;D
