November 27, 2024, 18:34
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
Inbox.com
Topic: Inbox.com (Read 2490 times)
Inbox.com
October 06, 2012, 16:23 »
Mrs Clive accidentally downloaded Inbox.com the other day and it hijacked all her web browsers including Chrome, Firefox and IE. She tried uninstalling Inbox.com using control panel but it returned immediately in restart and system restore failed to remove it. I've just uninstalled Chrome in safe mode and downloaded it again and it seems to be fine now. I've also uninstalled Firefox and do not intend putting that back. Not sure what to do about IE because she will need that for Windows updates. I had a similar problem with a rogue browser called Conduit a few months back.
Re: Inbox.com
October 06, 2012, 16:27 »
Inbox.com is a free mail service that I've been using occasionally for years. Never realised it came with software now. Does this help, Clive?
http://toolbar.inbox.com/faq.aspx?faqid=2876&faqmod=wst_install
Re: Inbox.com
October 06, 2012, 17:00 »
I've managed to eradicate it completely now Simon and it doesn't appear in control panel. When you clicked on a browser it would load up Inbox.com browser instead of Chrome or Firefox and it would direct you to its own search results which were pretty poor. Just like Conduit this is malware a google search will show that lots of people have been attacked by it.
davy51
Loyal Member
Re: Inbox.com
October 06, 2012, 19:08 »
To get rid of all of it you might have to reinstall it and remove with this
Its a nasty little program it adds itself to the registry
http://is.gd/jkLrtJ
Re: Inbox.com
October 06, 2012, 22:35 »
Thanks Davy - it's a very nasty piece of malware.
davy51
Loyal Member
Re: Inbox.com
October 07, 2012, 00:20 »
CCcleaner will remove all races of it if its fully installed its a great program for removing programs from windows
If its partially removed it may not see it all
Re: Inbox.com
October 07, 2012, 12:35 »
The method I used was to delete both Chrome and Firefox in safe mode, restart, and then reinstall Chrome. That worked a treat. There are lots of very convoluted methods of deleting it on the Internet but I think that one is the simplest.
Inbox.com
