November 27, 2024, 18:41
Technical Help & Discussion
General Tech Discussion, News & Q&A
Adobe fixes 25 critical security holes in its software
Topic: Adobe fixes 25 critical security holes in its software (Read 1895 times)
October 11, 2012, 09:30 »
Adobe released an important update for its software on Monday, fixing 25 security holes. The updates affect Flash running on Windows, Apple Mac and Linux systems. In addition, Adobe AIR users on Windows, Mac OS X, Android and iOS are also advised to install an update.
http://nakedsecurity.sophos.com/2012/10/09/adobe-security-update/?utm_source=Naked+Security+-+Sophos+List&utm_medium=email&utm_campaign=5c94aed08d-naked%252Bsecurity
Re: Adobe fixes 25 critical security holes in its software
October 11, 2012, 10:15 »
Only 25?
October 11, 2012, 10:55 »
Isn't that enough?
Not usually...
October 11, 2012, 11:04 »
My bloody Secunia PSI is stuck showing it needs a Windows Update for the Malicious software removal tool. Sometimes that program is a curse.
October 11, 2012, 11:09 »
Isn't it just.
