Author Topic: Belkin Windows Easy transfer cable  (Read 3465 times)
« on: October 22, 2012, 16:47 »
This is supposed to transfer all my files from my old XP desktop to my new Win 7 laptop.  It's very easy to follow the instructions but it just doesn't work!  It says the USB cable is not connected so I have to use a network instead.  Soooooo I set up a network following the instructions but that didn't work either.   :bawl:  Now I'm using a good old 12 Gb memory stick to extract everything.  It only comes to 4.4Gb all told so I don't expect it will take too long.
Re: Belkin Windows Easy transfer cable
« Reply #1 on: October 22, 2012, 18:05 »
I always use the network or a USB hard drive, the latter being faster than a standard 100Mbs network.
« Reply #2 on: October 22, 2012, 21:04 »
The deed is done now but I've had to forfeit my beloved Outlook Express for crappy Windows Live Mail.  That's progress!  ::)
« Reply #3 on: October 22, 2012, 22:14 »
You could always try Thunderbird. Or proper outlook if you wanna pay some cash.
Online Simon
« Reply #4 on: October 22, 2012, 22:31 »
... unless you know a student.   ;)
« Reply #5 on: October 23, 2012, 14:39 »
Mrs Clive uses Thunderbird but doesn't really like it that much.   :(
« Reply #6 on: October 23, 2012, 16:27 »
You do. Me again. Though the student deal for office these days is the same as home users. It's w**k.
« Reply #7 on: October 23, 2012, 20:47 »
Mrs Clive can get those worthless deals too.  Just loaded Office 2000 onto my new laptop.   8-)
« Reply #8 on: October 23, 2012, 22:04 »
Living in the future there!
« Reply #9 on: October 23, 2012, 22:05 »
you'd so be better off with openoffice at that point!
« Reply #10 on: October 23, 2012, 22:20 »
2000 is more than adequate for my simple needs.  :P  Besides, it will install as many times as I want - unlike my copy of Office 2010 which cost £80 and only had 3 lives.   >:(
« Reply #11 on: October 23, 2012, 22:23 »
Its shocking isn't it. I think you can probably contact them and say you have changed the computer. You are paying for a licence not software really with the newer ones.
Online Simon
« Reply #12 on: October 23, 2012, 22:33 »
Yes, I agree, once you've paid for it, you should be able to use it as you please.
« Reply #13 on: October 23, 2012, 22:41 »
I actually prefer 2000 and see no reason to have 2010.  Mrs Clive disagrees.   :laugh:
Online Simon
« Reply #14 on: October 23, 2012, 22:42 »
I still have 2003, and see no reason to upgrade.
