Author Topic: caps lock key problem  (Read 4096 times)
Offline jww41005
« on: April 23, 2013, 10:31 »
Hi Pals,
Odd problem.
When caps lock is activated it changes the keyboard, for example, when I press c, zc appears, and if the printer is on it will print it.
Updated driver and I've tried rebooting and resetting the keyboard (Spanish) but it didn't work.
Windows 7
Presario CQ57
Any ideas
Cheers
« Last Edit: April 23, 2013, 11:30 by jww41005 »
If it works, don't fix it
Re: caps lock key problem
« Reply #1 on: April 23, 2013, 11:44 »
I suggest the first thing to try would be another keyboard.  Then you'll know if it's the keyboard itself at fault.  Have you turned it upside down and given it a shake to see if anything drops out from between the keys?
Offline jww41005
« Reply #2 on: April 23, 2013, 18:41 »
Hi Simon
Thanks for that
Maybe I should have pointed out that it's a laptop so the cure is probably more complicated.
My previous laptop had a crumb under the key problem, which was quickly fixed.
The keyboard works fine until I activate caps :dunno:
It's not really a big problem as I can still use shift, but I would like to get to the bottom of it.
« Last Edit: April 23, 2013, 18:44 by jww41005 »
« Reply #3 on: April 23, 2013, 19:04 »
Can you take the keys off? Might just be a bad contact.
It could also be software. Boot off a live CD and see if the same issue happens?
Offline jww41005
« Reply #4 on: April 24, 2013, 12:39 »
Hi Sam
I managed to remove the key, almost broke it because it was connected with two small hinges. It's clean.
I also think it's a software problem and the laptop didn't come with a CD, so....
I'll have to scratch my head a bit more, after a tinnie.
Thanks!
« Reply #5 on: April 24, 2013, 12:50 »
Might be a silly question but does it do the same if set to English language?
« Reply #6 on: April 24, 2013, 20:07 »
Try a Ubuntu live cd? https://help.ubuntu.com/community/LiveCD - see if it boots with the same issue.
Offline jww41005
« Reply #7 on: April 26, 2013, 11:07 »
Hi Pals
It's fixed!
One of my students had a look at it, a software engineer. She gave it back to me in full working order.
I asked her how she fixed it and she just said you won't understand :dunno: I will try asking her again, maybe.
Thanks
John
« Reply #8 on: April 26, 2013, 12:04 »
That probably means she gave it a shake!  ;D
« Reply #9 on: April 29, 2013, 22:05 »
Hi Pals
It's fixed!
Thanks
John
Would be nice to know how.... I expect I'll be able to understand he technobable.
