Author Topic: Dun Connection  (Read 1730 times)
Dun Connection
« on: May 23, 2003, 21:46 »
I have set up my own dun connection. What | would like to know, should I be unticking "enable software compression" or leaving it ticked. ???
Re:Dun Connection
« Reply #1 on: May 23, 2003, 22:04 »
I've always left DUN connections "as found" and I have not experienced any problems Lona.  I'd leave it ticked.  I'm sure that others will comment though.
Re:Dun Connection
« Reply #2 on: May 23, 2003, 22:22 »
I always tick it Lona ;)
Best advice is to try it with - if it doesn't work untick it and try again :)
Re:Dun Connection
« Reply #3 on: May 23, 2003, 22:35 »
When it was ticked, I was having quite a few cutoffs.  I read a post on ispr review about cutoffs and it advised unticking it.  So far, so good but could be co-incidence. What does it mean anyway??
Re:Dun Connection
« Reply #4 on: May 23, 2003, 23:29 »
I always set up my DUN connections manually and the only boxes I have ticked are Enable Software Compression and  TCP/IP.
I don't know the technical details (perhaps someone else can explain) but some ISPs support compression, which allegedly makes pages load faster.
Re:Dun Connection
« Reply #5 on: May 23, 2003, 23:43 »
I set up my own connections as well, Chorleydave, and both were ticked, I will retick "enable software compression". :)
