Author Topic: Microsoft Netmeeting  (Read 1739 times)
Offline Whiskas
« on: May 24, 2003, 11:05 »
Has anyone used microsft netmeeting on here? I have just tried it but it keeps saying that the server is incorrect, any ideas on how to fix it?
Re:Microsoft Netmeeting
« Reply #1 on: May 24, 2003, 13:16 »
Were you trying it between 2 people with the same OS Whiskas?
I havent seen that particular message but for some reason if you are trying to use it with someone on XP,and if I remember correctly you are on 98,then it will only work if you initiate the contact.If XP tries to contact 98 it fails.
Prior to attempting to contact anyone did the system check and set up your audio and video correctly or did problems occurr during this?
Offline Whiskas
« Reply #2 on: May 24, 2003, 13:32 »
I hadn't actually got as far as trying to use it with another person Sandra it seems to happen as soon as I load it up. I thought it may be that it has old servers or something like that because I tried all the different ones available but I have the same message with all of them
« Reply #3 on: May 24, 2003, 17:44 »
Have you tried unistalling and reinstalling it Whiskas,not sure if it will help or not but thats got me stupmed for now sorry  :(
« Reply #4 on: May 24, 2003, 18:03 »
Just found this on the microsoft knowledge base Whiskas :
http://support.microsoft.com/default.aspx?scid=kb;en-us;q165451
I think you were with AOL werent you?
« Reply #5 on: May 24, 2003, 18:07 »
Sorry Whiskas I forgot that its BT internet you are with,AOL was your other option wasnt it  :(
Have you tried disabling your firewall and trying to connect  ???
